applumb@live.com
- Messages
- 2
- Vehicle
- T5 SE 140
hi I have got a 2014 140 dsg cali how will I know if it has tow bar prep or will I have to ask the dealer
Following up on your original question. We have now received our new Cali and I checked the sticker on the drivers seat and it does have the 1D7 code which means Tow Bar Prep has been done.hi I have got a 2014 140 dsg cali how will I know if it has tow bar prep or will I have to ask the dealer
On the seat base, under dashboard or in one of the handbooks.Where on drivers would this be cannot see any stickers
PF Jones can fit the same towbar that the factory fit but have developed a wiring loom that goes under rather than through the vehicle which can be a problem with the California. They have mobile fitters and agents around the country.Found label under steering wheel
Sad no pre prep
Will need full instal
Hi Welshgas, What problems have been encountered with the factory fitted (through the vehicle) wiring loom?PF Jones can fit the same towbar that the factory fit but have developed a wiring loom that goes under rather than through the vehicle which can be a problem with the California. They have mobile fitters and agents around the country.
Betty67 - I assume if you spoke to Breeze you are in Dorset/Hampshire. If you need to do any coding with VCDS I could help out - we are in Ferndown.Just got quote from breeze ouch £1900
Pf jones it is then
