Stu@rt
I love that analogy !Great to hear as your kids get older it only gets better, for me there is no better vehicle its like driving a Swiss Army knife lol
Have you made any momentous decisions yet Stuart ?!I love that analogy !
I wish i had some news to share, sadly not! But obviously still very much lurking on here, so keener than ever.Have you made any momentous decisions yet Stuart ?!
Oh thats a shame but you will know when youre ready !I wish i had some news to share, sadly not! But obviously still very much lurking on here, so keener than ever.
I just need to get brave enough to pull the trigger and park all the doubts and concerns. Can I ask if you have a build week allocated? Has it been pushed back at all?
There are two different temperature settings. One is for Heat Continuously the other is for Heat Immediately. When you press the keyfob it activates what settings you have in place for Heat Immediately, so check those out.Aux Heater update
i have now set all heat settings to 10, this has defiantly helped when i leave my VW for a 15 minuets to a hour while i go to a meeting or shopping etc, now the weather is getting colder coming back to a warm van is great. The only thing that i would like to improve is when I click the heat button on the remote control the van is always cold when i open the door even when its been on for 45 mins, really scratching my head with this one as the heater vent even feels cool
which settings are used for the time/duration activated heating?There are two different temperature settings. One is for Heat Continuously the other is for Heat Immediately. When you press the keyfob it activates what settings you have in place for Heat Immediately, so check those out.
I have a 6.1 and initially had the same problem. This resolved by using the key activation of immediate heating. This started to work and then the continuous mode worked. I think this is because the heater was new and unused. When started a few times it seems to work. Hope this works for youHi all,
I have just taken delivery of my T6.1 4 motion and have read the instruction book on the heater and watched various videos on you tube. I have it set to the correct mode but its not performing As it should (i have had the T6 prior so i know What heat it can kick out) I have even put the blower on maximum it blows for a few minutes then cuts out.
Has any one had this problem ?????
Hi there, I own a t6.1 California Beach, and from my experience I can tell the difference is "heat immediately" stays on for 30-40 minutes and then stops. I guess its just for when you want a quick boost of hot air to raise the temperature in the van like for example when you come back after a day out and its cold inside.He doesn't cover the differences between "Heat Continuously" and "Heat Immediately" in the video sadly.
Yes. This is exactly how I understand it to workHi there, I own a t6.1 California Beach, and from my experience I can tell the difference is "heat immediately" stays on for 30-40 minutes and then stops. I guess its just for when you want a quick boost of hot air to raise the temperature in the van like for example when you come back after a day out and its cold inside.
While heat continuously keeps working on all the time with the thermostat switching on-off when temperature is reached (I think its something between 20/21 degrees)
Thanks for this HallelujahOK - i think i finally understand these settings - or at least how i use them.
Heat Immediately - this is your 'quickly get the van hot as a one off' option. You kick it off via the control panel or via the remote fob. It heats to whatever level is set in the Settings. Once it gets to that heat it switches off and will not resume. You use the fob in the morning 10 minutes before you head out, while eating your smoked salmon and scrambled egg. When you get in the van warm and the windscreen is cleared. Its not for maintaining heat - just for getting hot as a one off. It makes sense to work this way because it is activated via the fob. You wouldn't want to accidentally activate it and then its running down your diesel all day unawares. Do not use this when going to bed at night. As once the temp it reached it just switches off and you'll wake up cold in the night.
Heat continuously - unlike the other option this is activated ONLY via the control panel and you always have to specify the heat level when you activate. This will continuously maintain that temp. Switching itself on and off as the thermostat detects the desired temp. This is for when you are in the van - camping and sleeping. it will maintain a nice steady heat for you.
The manual is terrible at describing these two options. It's taken me a week to work out whats going on.
So have it confirmed from the We Connect team. Unfortunately I can’t operate the Aux Heater from the App. (Suspect this is the case for some of the other nice to have functions too). A bit disappointing because the Cali is definitely a vehicle that this would be very useful on. See below:-I have just checked and I cannot find the ability to operate the heater either via the WeConnect app or the web based version.
Yes it’s a bit underwhelming. :-(Hi all...
You definitely cannot operate the heater from We Connect Plus . (only switch on and off from last saved setting on the Heater remote key fob)
I must admit that I am a little disappointed with the We Connect app.. It could be a lot better I feel, function wise. It would have been really great if all the functions on the Control Panel could be reflected in the App for instance.
You cannot Lock or Unlock the Cali from WeConnect Plus.
WeConnect Plus will tell you if the doors are locked or unlocked (I guess that's what VW mean by "Manage")
You can get receive a notification (as long as this is set from the app on your phone) to tell you that the vehicle alarm has gone off and the notification will distinguish if the alarm was caused by a trailer or light board being unplugged.
You can receive a notification that your Cali has moved out of "pre configured by you" areas.
You can also set up a speed alert to notify you if your Cali has exceeded a set speed - quite why you will want that I don't know. Maybe useful if you hire the Cali out.
You can activate (pulse) the Horn and/or (flash) the lights if you want??!!? from the WeConnect Plus app. Presumably to find where you parked your Cali if you need to (or maybe frighten somebody off)
The Discover Pro has a software SIM built in which is used by the SOS system, servicing and map updates etc
To enable Internet Radio, media streaming and the Wi-Fi hotspot (use your Cali as a stand alone WiFi hotspot) you have to purchase an additional data plan from VW's chosen provider CUBIC TELECOM.
Instead of a VW data plan, you can create your own Internet connection via “Personal/mobile hotspot” on your Internet-ready end device i.e. tether your mobile device using its own data plan.
As far as I remember I was able to unlock the car using the app.Hi all...
Same here. Can’t unlock with the App. Doubt i’d normally use it, but I suppose it would be VERY useful if the key was lost or locked in the van.Hi all...I am referring to the Weconnect UK iphone app on a MY21 T6.1 Ocean and it isnt possible. You can see that the vehicle is locked or unlocked but no option to lock or unlock from the app. View attachment 69690
