Borris
Over the many decades since I got my first car I've done much of my own servicing, that is on those vehicles that were outside of the warranty period. In my experience, most servicing is pretty straight forward so providing I pick a nice day and organise myself then things shouldn't be too difficult. However what very often makes the whole process a PITA are the Motor Factors.
Yesterday I decided to take advantage of Black whatsit discount and order the necessary to do an annual service on Mrs Bs motorcar. So having played this game many times before I always check to see if there is any danger of said parts actually fitting the vehicle. I repeated this procedure this morning when I went to collect my order from a well known motor factors that specialise in European cars. "Can you please double check that these parts will all fit that car out there? I said to the young man behind the counter. "Yes mate, the fuel filter can be tricky but there's only one listed so you're ok"
Twas a nice sunny day so out came the tools. All went swimmingly until it came to changing the oil filter. Having jacked up the car, removed the under tray and dropped the oil I discovered that I had again been tucked up. The oil filter was the wrong one.
Last week I collected the correct discs but for the wrong car and the right box containing the wrong pads. The month before I needed new wipers. That took two trips to get that right. It's never been any different either. You can give them your registration number, make and vehicle model, chassis number, engine number and mothers maiden name but it seens to make little difference. The chances of playing and winning is depressingly low.
That's it rant over. I'll take it back on Monday and join the queue with the other losers.
