1. A breaker bar with a 19mm socket for wheel changing.What tools do the seasoned California owners carry? In a normal car it’s minimal but just wondered what experience has taught the ‘old hands’?
Thanks.I carry far too many, but then I have experience of being caught out not having the right tool. I have a spanner, screwdriver including torx, for every fixing. Full set of trim tools, battery charger, many spare fuses, wire, tape, hack saw, jack, multi-meter, jubilee clips all sorts, tyre pressure and depth gauge, pump, tyre sealant and repair kit, spare bulbs. All of it has been used on trips at some time or another and have always been able to get to a garage. Far too much kit but I can't think what to leave behind.
Two points:Thanks.
Need to add a set of trim tools to my kit. Where do you stash your toolkit? I’m looking to maybe use the void under the drivers seat for some of it?
Thanks for the advice - maybe not the best location under the seat!Two points:
1. Why does anyone need trim tools in the van? I have a set at home but I can't think of any reason to have them available in the van all of the time.
2. Be careful sticking too much stuff under the drivers seat as it can disturb the cables when the seat is swivelled. That can throw up warning lights which may require a trip to the dealers to rectify.
That’s a great toolset.I keep a breaker bar & wheel nut socket, a general rechargeable camping lantern, Stanley knife, lump hammer & this Teng toolset that Ive had for 20+ years, it takes up very little room & has everything I need for fixing bikes, rewiring trailer plugs etc.
I remember paying £45 for it on clearance at Halfords in Tottenham Hale in 1996 its about £300 now!!That’s a great toolset.
This is pretty close to being your kit. https://www.tradetoolsni.co.uk/product/teng-tools-tm095-95-piece-14-12-socket-set/I keep a breaker bar & wheel nut socket, a general rechargeable camping lantern, Stanley knife, lump hammer & this Teng toolset that Ive had for 20+ years, it takes up very little room & has everything I need for fixing bikes, rewiring trailer plugs etc.
Not really - that set only has a couple of the combination spanner’s & more importantly hasn’t got the 3 different pliers & wire cutters which are what makes it better than just a bog standard socket set.This is pretty close to being your kit. https://www.tradetoolsni.co.uk/product/teng-tools-tm095-95-piece-14-12-socket-set/
Is that a Leatherman @Borris ?1. A breaker bar with a 19mm socket for wheel changing.
2. A pair of gloves to keep your hands clean whilst doing it.
3. A head torch because it will always be dark.
4. A mobile to call VW Assist if it's raining or I can't be @r$#d.
2. A Leaderman multipurpose tool for general camping and every day use.
Probably better I don't have a tool kit at all if I cant spot that difference!Not really - that set only has a couple of the combination spanner’s & more importantly hasn’t got the 3 different pliers & wire cutters which are what makes it better than just a bog standard socket set.
Yes, Sorry I thought it was something like that.
