Calimili
Could it be that with gas and water the LH side is loaded more than the RH side , therefore in your pick the arch gap is so higher on the RH ?
No. The other side looks just as high.Could it be that with gas and water the LH side is loaded more than the RH side , therefore in your pick the arch gap is so higher on the RH ?
Not very good for the tyre wall cords especially if left sitting on under inflated tyres.Before you start replacing your garage doors check you can't get the van in with just letting out some air. We moved house and were worried I wouldn't be able to get it into the new garage. I had two tactics - first let down tyres and if that didn't work I was going to remove the awning which is the high point on the roof. In the end with my wife watching very carefully standing on a box we got it half way in and then it was about to touch the door. so then we just let the rear tyres down maybe to half inflated and it got in with ease. Realise you can't do this in a public car park but good for storage if your garage doesn't have easy clearance. Just need to be careful when I go out in the van to make sure the air has not expanded with the increase temperature as we move towards the summer. Letting the air out is an extremely minor issue compared to not getting the van in or having to buy new doors! And yes I have a tyre inflator so it only takes seconds. Hope that's a helpful tip since it has saved us loads in storage charges or buying roller doors.
I don't know, its why I would like a few measurements from others to see if it really is a problem.Hi @andyinluton, can I ask just how many members have reported this? Does sound concerning that we might have an issue where VW have delivered a vehicle different to that specified in the brochure. I am guessing that there will be plenty asking for the van to be dropped onto shorter springs at VW's expense it it has been wrongly advertised. Anyone spoken to VW, or their Van Centre and complained yet?
I’m not sure it is wrongly advertised- their brochure shows 1990mm to the roof of the base van. The pop top height isn’t referenced…Does sound concerning that we might have an issue where VW have delivered a vehicle different to that specified in the brochure. I am guessing that there will be plenty asking for the van to be dropped onto shorter springs at VW's expense it it has been wrongly advertised.
ConcurThe barrier will always have some leeway, but be more worried about the lowest point in the carpark itself - ie low hanging pipework etc (unless it’s a Beach carpark of course!)
Thanks, the tyres still have quite a lot of air in them (as you can see in the photo) but to make sure I will put some more air in since once it is in the garage there is no headroom problem anyway - just must remember to deflate again before I take it out of the garage!!!!Not very good for the tyre wall cords especially if left sitting on under inflated tyres.
It might be different in Sweden, but here in England there are an increasingly large number of height barriers, both at sea-side locations & city centre car parks that are set at 2m. Not being able to use them would be a major blow.My T5 SE is 205 cm high in the right rear edge where the awning is mounted. But the awning is an accessory and accessories can be opted out, but that is a completely different matter. But I see it as a storm in a thimble.
Oh dear - just checked mine & agree - if VW are only lowering the front it doesnt help with the car park 2m height !Any way - bombshell announcement, see photo below its supposed to be 2030mm !!
Well, if I'm not welcome there, they will not get my moneyIt might be different in Sweden, but here in England there are an increasingly large number of height barriers, both at sea-side locations & city centre car parks that are set at 2m. Not being able to use them would be a major blow.
I had a lot of clearance under a 2m barrier in my old cali.Whenever I have checked under a 2m barrier there has always been a decent clearance, so much so that I think the barriers are deliberately set higher than the height warning.
Wow! Loving the inconsistency between brochure & manual.Note the brochures view of the California's versatility (and the sub-text #4)
