Leisure battery not holding charge
Make life easy for yourself and get one big one, less faf with connectors etc.C1059536-52B7-4D11-9661-7288314F61D9.jpeg
For ref, when adjusting your control panel use the Sonnenchein setting if you use this Exide battery.
Hi again, anyone happen to know if 2 x 86ah Batteries would be suitable? There are some available locally and they fit snugly in the cabinet. My old ones were 105ah.
Blinding. Do make sure you connect them in parallel.
....thats poz to poz, neg to neg.
Yep, I made sure I took pics as I took them out, so I can retrace my steps! I’m thinking 2x86ah is probably enough as I only really run the fridge and we tend to use hookups at night.
They should be fine. The latest California only has 2 x 75amp Leisure Batteries.
