Windscreen wash hose split
sbmcd
sbmcd
Edinburgh
T6.1 Ocean 150
Hi, went to use my windscreen wash yesterday to see the wash mix squirting out of the nearside end of the bonnet. Found that the hose has split where it takes a tight bend when the bonnet is closed.
Could not find anything on this forum but found this is not uncommon on an other forum. The repair solutions I found were mainly using hose connectors of some sort.
I used a short piece of flexible motorcycle fuel pipe, secured with small cable ties, very easy to install and provides excellent flex without crushing crushing where the tight bend is.
Could not find anything on this forum but found this is not uncommon on an other forum. The repair solutions I found were mainly using hose connectors if some sort.
I used a short piece of flexible motorcycle fuel pipe, secured but small cable ties, very easy to install and provides excellent flex without crushing crushing when the tight bend is.
I just wound sticky, flexible, stretchy insulation tape around the tube for about 2" either side. Survived 3 yrs so far.
Even easier than mine, but it leaves the issue with the tight bend, we will see how long my repair lasts and compare lol.
