Carrying a motor scooter on the back
IanE
IanE
Kendal
T7 California Ocean 4 Motion
Just wondered if anyone has done it/looked into it? You see plenty of motorhomes with what looks like a platform attached to the rear, but we haven't seen a VW T5 doing it? Clearly there'd be difficulties getting the tailgate open with the scooter/small motorbike in place! Just seems a lovely lazy alternative to push bikes. We do have one electric bike which is great but lacks range - acknowledging that the Kalkhoff does very well!
Cheers
Ian
Cheers Danny - wow! Don't think I fancy lashing a scooter to the bottom of our VW bike rack!
It was on a dave cooper motor bike rack which goes on the towbar. The towbar has a nose weight limit of about 110kg so could have almost put 2 monkey bikes on the back! The bike rack was filled with camping bits in a fiamma bag
Oh right - thanks for that Danny!
7 year thread revival :)
Just seen the Piaggio One electric scooter advertised. £2000. Looks good and with a weight of just 49Kg I assume I could carry it on my Thule Velospace XT3 which has a Max Load capacity of 60Kg.
Thoughts?
Thoughts?
Great idea. How would you charge it when away from home? Could you use the EHU on sites?
Yes, would need to rely on campsite hookup I think. I have an additional cable with a T off to a 3-pin socket so could easily charge it outside the van.
The Piaggio One only has a range of 35 miles, but they do a version called the One+ that has double the range. Not sure of the weight of that one?
35 miles is enough to pop out to a shop / takeaway / park near the beach for 99.9% of our trips. Looks worthy of further investigation.
Its £2500 for the slowest one, the battery is removable so weight in transit could be quite a bit less.
For access to rear via tailgate I'd favour a sideload trailer. Clearance may need checking with tailgate upswing.
No weight issue with Scooter giving a wider product range to select from.
.http://www.cmftrailers.co.uk/side-load-trailers.html
For access to rear via tailgate I'd favour a sideload trailer. Clearance ma need checking with tailgate upswing.
I would sooner have a trailer than put extra strain on the rear suspension. If you got a box trailer although expensive you could carry all your extra stuff in there.
You would hardly know you were towing it.
Lost me there as it is a trailer that I suggested.
Interesting review here https://www.wired.co.uk/article/piaggio-one-review
One thing is sure, the more options that come to market the better the costs/choices will be. I'm not following the e motorbike market closely but it appears slower than the car market to offer sensible/low cost choices.
The Piaggio 1 seems a bit low seat wise.
That article suggests that there is an EV grant available that brings it down from £2500 to £2011
OK, i’ve checked the weight. Here’s a reply from a supplier:
Hi Mike
The Piaggio 1 and 1 Active weigh in at 85kg and 94kg respectively. The battery is 10kg for the 1 or 15kg for the Active. If the weight rules are strict for your carrier then you are looking at 15 or 20kg over your limit with the battery removed. We supply a lot of scooters for motorhome use, 60kg sounds very low compared to most, but the VW is a smaller vehicle than some I guess.
Hope this helps.
Kind Regards,
Ron Daley Scooters
I carry my Grom on the back of the bus. 90kg. Been across Europe several times. Barely notice it weight wise.
Interesting @sidepod .
I don’t think the weight of a Piaggio 1 is a problem for the Cali’ but Thule has a max load of 60Kg for the XT3 rack.
This has been covered to death. (Search function!) There is a rack on the market (Fiamma I think) that is rated to 600kg.
I made mine based on that design.
Just a cautionary note
What are the requirements to fit a type approved tow bar?
If you wish to tow anything with a car, which was first used on or after the 1 August 1998 the car must be fitted with a type approved tow bar.
