SusiBus
2-pedal power Peppa Pig trike
Looking to order T6.1, and don't know what Pro gives you over standard "Discover Media" to make it a worthwhile option.
Can any one help?
Can any one help?
This might help.Looking to order T6.1, and don't know what Pro gives you over standard "Discover Media" to make it a worthwhile option.
Can any one help?
I am also about to order a T6.1 and I am struggling with what is extra with the "Pro". A smidgen of info hereThanks Welshgas, better info than I had found.
It seams that the T6.1 system is already out of date even before a T6.1 has been delivered, because it mentions the new Golf being available with a 3D 9.2 inch touchscreen as opposed to the 8 inch being fitted in the Cali.
It mentions the Pro having 3D mapping as opposed to 2D/2.5 any body had any experience of 3D mapping or the other options that justify the extra £666.
Whilst sitting in relative darkness watching a movie last night I noticed, on a couple of occasions, the touch screen ‘buttons’ momentarily flash on. No apparent problems with the van but just but wondered if anybody else had seen this? Roof was up and the only active systems at the time were Fridge and Aux Heater.
Thanks @andyinluton , interesting.Mine does something like that - its less of a flash, more like the screen flickers less black if that makes sense. A bit like when the TV at home is switched on but not showing a picture. Only happens if the fridge is on.
The built in sat nav receives free updates, so shouldn't be out of date. Once you've signed up for We Connect it brings the traffic etc in. This allows the sat nav to be displayed on the digital dash, which I don't think Car Play can be.I haven’t upgraded to the Pro as I can’t see the value in it, I could be wrong, but here’s my take, the standard unit has
Whilst the Pro version physically looks better I cant find anything that it doesn’t do that the Pro does.
- Wireless CarPlay
- Navigation displays in the Digital Dash
- Physical control knob
- Same speaker set up
Note I use Apple CarPlay 99.9% of the time so have no interest in the VW built in Sat Nav, which to me will be out of date before the Cali arrives.
Its the bigger screen that makes the most difference especially when using CarPlay in a split screen mode, it just gives a much bigger area to show the maps in.
Ive not found the built in maps to be out of date.
One beauty of the split between the screen and the digital cockpit, using VW nav, is you can move away from the large map on the screen (to eg car play music) and the route remains on the dash.Just realised you mean the split screen on the single screen right. I thought you meant split between the main unit and the Digital Cockpit
Seems ok for re-routing & I've not found the live traffic to be wrong ie it shows the queues pretty accurately.What’s the VW system like for rerouting you if there’s an accident a few miles up the road? Or warning you about a broken down lorry or lump of retread in the carriageway?
The Vw system shows current speed limit & adds an exclamation if you are over it. You get a huge digital number right in front of the driver showing how fast you are currently going!I use Waze, great in traffic and displays my current speed + the speed limit.
We have the 9.2" screen and it gives a bit more detail / has more pixels on your nav-map and the 3d nav. We have a preordered vehicle, but I'm pretty sure I wouldn't order it myself also because of the fingerprints..View attachment 86813
