You can get a 3 pin adaptor plug that goes on the cable end that normally plugs into campsite feed.Hi all, i got my t5 cali 2009 summer last year. Going to use my electric hook up next week for the first time, i hope it works. Anything i should do, or just plug it in? Anyway of testing at home before i go? Thanks Phil
It did say it in the handbook to plug in once a month on our old t5, can't say I've looked in it for the 6.1Seeing how you mention that you have owned it for a while, but have never plugged it in, have you checked the condition of the batteries? Most people (but not all) think it's a good idea to hook the van up at least once a month to keep the leisure batteries healthy.
Or fit a couple of solar panels on the roof, then no need to worry.Seeing how you mention that you have owned it for a while, but have never plugged it in, have you checked the condition of the batteries? Most people (but not all) think it's a good idea to hook the van up at least once a month to keep the leisure batteries healthy.
Most people including VW engineers...Seeing how you mention that you have owned it for a while, but have never plugged it in, have you checked the condition of the batteries? Most people (but not all) think it's a good idea to hook the van up at least once a month to keep the leisure batteries healthy.
But not the vw engineer that wrote the T6.1 manual unlike earlier versions.Most people including VW engineers...
The OP has a 2009 Cali, definitely not 6.1, and Thomas HJ, who I replied to, has a T5.But not the vw engineer that wrote the T6.1 manual unlike earlier versions.
Hey Andy, I just haven't read the 6.1 manual I still plug ours in every monthI’d just seen Sads response mentioning T6.1 I hadn’t read further up the chain.
I think you are expected to use the “boost” button occasionally on the T6.1 - If you have a beach tour that’s your only option, no hook up provided.
Hi, sorry for the delay, i have just seen your message, i`m now charging at home thanks to your advise on how to do so from home. Do you have to remove any of front seat to get to battery, it has a rubber cover over it, plus i presume this is how to get to the fuses under seat, Sinks not working and can`t find a fuse layout.Seeing how you mention that you have owned it for a while, but have never plugged it in, have you checked the condition of the batteries? Most people (but not all) think it's a good idea to hook the van up at least once a month to keep the leisure batteries healthy.
I got to the fuses, they are tight to the righthand side, i can just about get the top ones, but can only just see, let alone got to the bottom 3. The tap clicks when i turn on, just wanted to check fuses before the water pump itself.The fuses under the front seat are easy enough to get to. Just move the seat backwards and you will see them. By 'the sinks not working' I assume you mean the tap? If so, there's many thread on the forum that explain what the problem could be and how to fix it. Could be the pump, or themicroswitch in the tap. etc.
If you move the front seat forward you can get to the battery. Assuming you own a SE (Ocean) there's a second battery in the back of the van behind the hatch. You can measure them with a multimeter, but you can also start with reading the battery voltage on the control panel a few hours after you have done a full 24h charge on EHU.
Log book just says Transporter Caliornis SE 174. Not Beach or OceanThe fuses under the front seat are easy enough to get to. Just move the seat backwards and you will see them. By 'the sinks not working' I assume you mean the tap? If so, there's many thread on the forum that explain what the problem could be and how to fix it. Could be the pump, or themicroswitch in the tap. etc.
The SE is the forerunner to the Ocean, same camping layout .Log book just says Transporter Caliornis SE 174. Not Beach or Ocean
