Overthinking it because I don’t agree with you, maybe.What issues are you expecting? You appear to be overthinking it.
It’s no different to the ocean having a battery at the front & back.
Put a large cube fuse on the back +ve connection if you are worried about overloading anything.
What is it that you don’t agree with?Overthinking it because I don’t agree with you, maybe.
My point is, the cabling was not installed with the intention of charging a battery. A fuse is not going to help that.
It is completely different to a van purpose built with batteries in those locations.
AFAIC this set up forces the installation of an identical battery to the original leisure battery - same size, same age, same chemistry, same charge / discharge characteristics. I’m not too confident in charging through 1+2 for the reasons others have raised but perhaps it’s fine. Regardless, I’ve concluded I’ll put a dc-dc charger in so I can go with a larger deep cycle AGM battery and then in the future maybe a lithium. I’ll update on the install over the next week or so.What pitfalls?
Nice @T3Z-GB! Which batteries have you gone for and where are they located?Iv gone all out on the electrical upgrade.
Attached pic… iv still yet to tidy it up a little,
and give the full schematics as promised, iv just been to busy.
In the meantime the van is now mostly electric apart from the cooktop, Waiting on a price to remove the gas burner sink combo and replace it with a induction top. After that the gas will be removed.
And then reconnect back to the consumer unit.
Thanks Andy,Nice @T3Z-GB! Which batteries have you gone for and where are they located?
The fact you clearly don’t understand is what would worry me. Im not going to explain it to you.What is it that you don’t agree with?
There isn’t special cable made for charging batteries - any cable of a big enough size will do.
Why do you think it is any different to a purpose built van with the batteries in those locations ie an Ocean?
It’s simple basic electrics, when it comes to connecting two batteries together there aren’t a huge number of ways to do it.
Don’t forget to add on all the extra things you will buy that you never new you needed!It’s works ok for us;
Product details
Perfect for the smaller kitchen or wherever you need an extra cooking zone.
You can quickly start cooking since the hob easily plugs in with the included plug.
Induction hobs are extremely energy efficient, fast and precise as induction technology transfers energy directly into magnetic cookware.
The touch/press control panel allows you to regulate the heat easily and precisely by just touching the + and – symbols.
Always put the hob on a flat, stable surface when using it.
Hob with induction cooking zone: 1x175 mm.
1x2000W induction zone.
Connection rating: 2000W.
Current: 10A.
Voltage: 220-240V.
A Jackery won't run that at the rated spec, the inverter of the top model is only 1800w.For anyone frightened of torching their van because they haven’t a clue about messing with the electrics here’s our alternative hob.
If you want to park up in some remote spot or car park you will need a Jackery!
IKEA cheap as chips
Hi Eberhard, for me personally I wish to last a long weekend without using hook-up. Often I am camping at festivals with no mains electricity and to be honest I have no need for 230v power (hardly ever) but I would like to be happy knowing that my 12v leisure setup will keep the fridge cold, give me lights when needed and pump some water as required. A long weekend could be Friday to Monday, without moving.Hello,
I was (and actually still do) reading many tests, watching many Youtube videos and following posts in different foren that I totally lost overview.
Following are just my thoughts about the electric supply of a camper, thinking out loud (thinking in writing ). Just thinking is it worth to spend so much money?
I also wished to have a better electricity supply build in the Grand California, but because I can't do it myself I need a company doing this for me, which I can't find in Ireland at all. Also it seems that the Grand California is designed to be extremely complicated in comparison to other campers that there In general I starting to ask myself, do really so many people stay longer in one places without any supplies? Or is it a hype to upgrade the camper just to be on the safe side?
Still VW designed Grand California,
Eberhard
I personally cannot see an a problem with this if you use the correct gauge cable and parallel connect it.So, getting back on topic, is anyone able to offer some fact/calculation based input as to whether the addition of a 2nd AGM battery will cause issues?
As @andyinluton has already said, this has been carried out by many German forum owners (several months ago) with no reports of issues, and no one raised concerns. I am genuinely interested to understand what the potential issues are with this. Please be friendly and supportive!
Thank you. I assumed the issue was whilst charging via the alternator and the cable run to the isolator, which I believe is 16mm2 according to other sources.I personally cannot see an a problem with this if you use the correct gauge cable and parallel connect it.
The concern for correct cable size is from a charging perspective, the alternator has the capacity to charge at 90ah + from a 180ah rating.
So assuming you completely discharge both parallel connected batteries you could potentially be sending 90ah + to the second battery 6 meters away. Using a cable chart, loads online, you would need a minimum of a 42mm2 cross sectional cable, to carry the current. Even if it’s for a short period.
The way I’d go about it is get a second leisure battery with same spec. Parallel connect it with jumper cables and, completely charge it and discharge at your home. Once you prove it works successfully. And get the additional run time, Then start thinking about how you run that thick cable from the front battery to wherever you install the second.
I do not need to work or live in the van, but would like to spend 3 days maybe 4 “off grid”. Whilst a jackary or similar seems to be the simplest option, it’s not cheap, or the most efficient way to top up the 12v leisure battery. I have no need for 230v power and so the attractiveness of the 2nd leisure battery is it seems to be the perfect solution for my typical usage/needs, and wouldn’t cost more than £200ish if it could be added as described by our German colleague.My situation is a little unique, I work and live full time in the van, have done so since August. I’m one of the fortunate who have always worked remotely, well for the past 16 years anyway.
That being said, I spent around £6500 on my electrical upgrade (including the second lithium) I charge and use laptops all day, cook twice a day, induction, microwave etc. Netflix or prime occasionally and obvs shower. (Induction since today .
I never go to campsites, and am usually remote all week. Due to the nature of my work, I usually find a new spot and stay for a week, working, and enjoying surroundings.
My upgrade powers all electrics in the van apart from the lighting.
My thoughts are unless you stay more then 2 days off-grid and work remotely, no need to upgrade anything. The van is perfect for that.
On the other hand, if you do, a quick power audit, multiplied by stationery off-grid days, assuming no sunshine and idle charge. For that a jackery or similar will do, but if you work and live, I think spending on a good solid reliable system is with the money.
