Mobile phone charging
NoviceCaliOwner
NoviceCaliOwner
Christchurch
T5 SE 140
Hi all
Beginner question , apologies in advance.
I have bought a 2013 63 plate 140 SE Cali Ocean. When trying to charge my phone using the cigarette lighter in the front, it says it’s charging for a split second then comes off charge?
Anyone know why this would be? Many thanks
Really excited about the Cali adventures and hope my kids of 9 and 11 aren’t too old to enjoy it for a for years to come.
Thank you
When I had those issues in my T6 it was due to the cable getting old and not connecting properly. A new cable sorted it.
Does you cable work ok elsewhere?
May also be the connector you are using in the 12V socket.
Can you try it in another socket and see if it works?
Thank you, the cable seems fine when connected to a power bank. I am thinking the cigarette to USB adapter might be the issue as I’ve heard some have more than 1 amp, which handles newer phones ?! I am just using a freebie USB adapter I’ve been given so I’ll try change that and see what happens.
Thanks for your response - I appreciate it
While at it, it may help to change the cigarette adapter with a usb socket, preferably usb c.
The cigarette lighter socket and most of the adapters that go into it, will go busy very soon.
Welcome and enjoy the adventures.
Thanks yes will look for those adapters that plug into the cigarette hole and offer USB C - assume that’s the best thing . Not too sure if you can change it any other way?
Thanks for your help
I meant, replacing the cigarette lighter socket with one of these
You will then not have a cigarette lighter socket but 2 usb ports.
Aah even better, thank you, those look good. Assume quite easy to install are they?
Thank you and sorry for all the questions.
I can see that you have a T5. I think the access to the rear part of the cigarette lighter is easier on the T5 if it is in the cup holder.
Did find a YT Video linked below
Thats great, thank you. Will have a look at what I can do... Thank you
The quality of 12v to USB chargers is generally very poor. I’ve even had one that interfered with my DAB radio. I have found since that Anker seem to make good ones, about a year in and working perfectly.
Haves1979
Haves1979
Haves1979
G
10K
Laura B
Laura B
