how do you clean the top of the awning, especially in the middle section & first turns?I assume you’ve checked there isn’t a twig or something caught on the top in one of the first turns, as the same issue can be caused by that.
Step ladder, long handled stiffish brush and warm soapy water.how do you clean the top of the awning, especially in the middle section & first turns?
I recently had tree sap on the top of the awning, very sticky and couldn’t get it off easily before winding in again. Result: sticky spots top & bottom now... :-(
No nothing stuck in it. Theres a crease in the fabric when the awning is extended, probably from not winding in flat!Try winding it all the way out so you can see where it’s taped to the metal roller... then get someone to hold the outer edge and guide it whilst you wind it in carefully. I assume you’ve checked there isn’t a twig or something caught on the top in one of the first turns, as the same issue can be caused by that.
Yes it was a pretty hot day. unwound it to dry it out from the pervious days rain and now it won't wind back flat!i've seen that before. usually in hot weather. i think the only cure is a new awning so try a warranty claim. a new awning may do the same though
I have the same problem.... just before creating new thread I found this one. Have you solved the issue? CheersHi, The awning on my 6.1 doesn't roll up flat and the awning has kinks in it as on the picture.
Is this normal or is mine faulty?
It's messing with my OCD
Try #3 on this thread.I have the same problem.... just before creating new thread I found this one. Have you solved the issue? Cheers
