Solar cable run - access?
I get that people are baffled by my plan! For me putting cables through the boot door seal is a bit like putting the garden hose on the kitchen tap through a window. I may end up doing that but I think this picture is a far more elegant solution and looks more OEM.View attachment 128618
it doesn't go through the boot door seal. anyway good luck with the install.looks good
Hi - think the best route is to make a tiny hole (with grommet) at the top of the pop top fabric, the entry hole is protected by a slight overhang of the roof. Then follow the same route as the LED cable - then through the grommet. Threading through to the wardrobe area is not so easy but possible, there are no hidden barriers. This, i think, makes the neatest installation. No drilling holes in the roof, just a tiny hole in the fabric.
I suppose if you used a heated bit to puncture the fabric, you would get a neat hole, and self seal so it wouldn’t unravel any further.
Disadvantage is, no go if your van is under warranty and potentially develops leaky bellows.
Wouldn’t the cable get trapped under the roof though when down? And could this distort the aluminium?
I may not be envisaging your idea correctly.
I've nothing against drilling a small protected hole in the roof to get an OEM looking solution. I will use a marine grommet which is very discrete.
Does anyone know how to access inside this part of the rear trim?
When i did mine i didnt touch that panel. i followed the same path as you through the roof and down the folding point and ythen drilled a hole above the wordrobe and fitted a grommet, and then staight down into the wardrobe. All good and its been fine for about three years now.
Interesting. Do you mean at the foot of the upstairs bed? Where in this pic?
thx
b
The hole is at the top of the fabric and is protected by the overhang of the ‘eaves’. The thin cable doesn't snag as the roof isn’t a complete seal anyway….
Thanks, I get where you’re intending now
As per some of the others the MPPT is mounted by the top shelf them the cable runs down the left of the shelfs and along behind the wardrobe and down to the leisure battery. And a monitor panel on the right side of the wardrobe door facing forward.
It's a bosswerk neptun 130wh panel, on a vagabunde plate.
In between is black channeled plastic.
Both glued with a product similar to sikaflex.
No connector needed, panel came with a long cable, 2 or 2.5 meters.
Victron in the upper cabinet.
Cable invisible inside
Scanstrut cable mount, high Quality.
All diy, around 420 euro Total.
Used 4mm2 solar cable to battery.
Inline fuses 15A
Looks great @ALFIrE! Is there anything between the aluminium plate and the roof? Does the plate flex at all and make contact with the roof?
Also, what is between the solar panel and plate? Is that corrugated cardboard?
Curious, what is the grommet used on the coiled cable ?
I think you're referring to the grommet that comes withe the van that routes cabling to the back door? I believe they've made a small incision in that, and pushed the coiled cable through it. I believe that's the conventional wisdom.
Do you mean the one just visible in the second pic if you zoom in?
Off on a tangent, I did the same installation and am now wondering if i can route my Starlink cable the same way if i can find a lighter gauge curly cable. Might start to look a bit messy though.
Been very pleased with my panel 5 years and no hook up since then, or pluggingin to charge every4 weeks.
Although there are some bolt on solutions just as effective they are nowhere as neat.
Hope OP got it sorted.
Dayum! That looks amazing! Where are the cables?!?!
Did you sika-flex directly to the roof? Did you put anything in between?
Grometed hole in roofrun down inside of canvas. Must admit didnt do it myself. Professional job at a very good coverters.
GrumpyGranddad
G
Private_Kelly
Private_Kelly
Private_Kelly
Roger Donoghue
Roger Donoghue
Roger Donoghue
Roger Donoghue
