12V System issue
AlexCli
Brasov
Grand California 600
Dears,
Please help if you have any opinion on this:
I recently replaced the leisure battery with a full Victron system (Lithium battery, Inverter, DC-DC charger, MPPT, Battery Protect, etc.). Now, I have no power to the water pump or ambient lighting (both interior and exterior) unless the inverter is switched on - or plugged into shore power. Everything else seems to work fine.
Thank you!
If you've removed the leisure battery what have you done with the GC factory shunt? That provides the charge status, current draw & voltage all of which are processed by the J608 unit to determine various parameters like when to shut down consumers within the GC, the water pump and lighting being two of them. What does your camper control panel show regarding the leisure battery charge % and voltage is?
Hi Gordon,
Thanks for your quick reply. Haven't touched the shunt don't know where it is.
The control panel seems to be showing over 12V, sometimes 14,4 after KFG reset - even when it reads 100%, water pump and ambient lights are not working. Tried to bypass the low voltage cut off relay for testing and still didn't work.
Do you have water in the tank, what does the gauge show, also the ambient lights (inside coloured strips) are powered by a victron DC converter which converts 12 to 24v. it's located in the "technical cupboard behind the panel, just remove the front and see if it's powered (lights up), who ever fitted your system may have dislodged something in that cupboard.
Hi Gordon,
If you've removed the leisure battery you've definitely 'touched' the shunt as its the white box with the comms lead on the -ve contact of the leisure battery. Have you just replaced the AGM with a lithium?
Apologies for butting in, Gordon is the expert but may I add that you mention the control panel shows 14.4 v which is a little high for charging lithium batteries, although OK for agm's. Did your converter disable the under seat charger.
Hi Gary,
Water-yes..
Ambient lights (inside/outside) warm white on 12V, they do work when the engine is on/ plugged in to shore or with the inverter on. I did the installation, haven't had one.
I have an Orion DC-DC charger for Lithium, the control panel might show the voltage of the starter battery sometimes. Charger under the seat not charging the Lithium.
I did removed the battery and installed an empty battery box there (as CarElectric does) but nothing connected to it - it's just to look good on inspections.
In the back, I took the 12V - 16mm wire from the main switch and powered the Orion DC Charger that feeds power to a Victron Linx Distributor.
Attached the diagram that I've used. As per the diagram, from my Lithium battery, through the distributor I feed the 12V consumers on the same wire that used to come out of the main switch.
As I have over 7kWh battery, I've already used it for long trips, charging E-Bikes, powering Espresso machines, hair drier, fridge. Everything works well, besides the top light and water pump.
And it's definitely not the low power cut off relay - I manually gave it signal to cut off and it does work but otherwise is disengaged.
My only thought left is that there is a relay that disconnects the starter and leisure battery positive and that the top light and water pump are not powered by the rear fuse box but from the wire that comes from this relay that now goes to my Orion.
  • Schema 50A.pdf
As Gordon mentioned, under the bonnet there was a connection (to battery) of a shunt/voltage monitor, this tells the VW system the battery condition, voltage, and what's going in and out (shunt).
You mention "ambient" lighting, this is the coloured lighting INSIDE only, and runs from a 24volt converter, the white lights are all 12 volt.
Also you mention that "sometimes the control panel might show the voltage of the starter battery sometimes". This is not possible. I suspect you've done something wrong.
