Crazy charging system is driving me mad.
G-A-R-Y
G-A-R-Y
Bristol S/W
Grand California 680
My leisure battery is fully charged according to the victron app. This morning I start the engine and drive to the beach, display panel shows -16 amps taking my leisure battery down to 70%. Pressing the battery boost button just increases engine revs with no increase in voltage. I think the only way forward is to fit a B-B. I've tried using the heated screen and seats to trigger battery charging but nothing works. I think it's a poor system.
Today I drove to the beach, I pressed the battery button, 14.6 volts all the way to the beach. Battery fully charged in 20 minutes.1000021981.png
Hi Gary. If you are drawing 16amps, that’s a load of 192 watts. The screen shot shows you are drawing 23 amps which is a load of 276 watts. What have you got plugged in that’s drawing this load?
The most I’ve seen my 680 draw is about 4 amps, 48 watts, with everything turned on, and charging phones, iPads etc.
Yes, that's exactly my problem. Leisure battery was fully charged via solar. When I started the engine I had a 25 amp draw. In effect my leisure battery was now charging my engine battery. It took it down to 12.2v. Even pressing the battery boost button did nothing. But today boost worked and my battery was nearly fully charged driving to beach.
How do I explain this to a dealer.
Low stater battery and blue motion trying to balance it out?
Guide posted as shows BMT behaviour
Hello Gary!
Did you find the root problem of this discharge? How did you fix it?
I have been to our local VW dealer 4 times, every time it takes weeks to get an appointment, they do some "adaptations"/software updates and say it will be fine, but the issue is still there.
We have replaced the leisure battery less than a year ago, at VW dealer, so they did something to "encode" it.
Thank you
This is how it's meant to be. Engine battery is never fully charged so that it can accept regenerative braking charge. It basically a commercial van system, NOT for leisure.
Leisure battery gets fully charged via solar, then when engine is started both batteries are linked via dumb relay under bonnet. So leisure battery affectedly charges engine battery.
Easy fix, my son has a camper electrical company. He fitted, Victron Orion B2B relay under bonnet and a Lithium battery, also fitted a lithium specific charger for leisure battery when on hook up.
He removed fuse 6 (under seat) to disable leisure charging from under seat battery charger.
The original under seat charger still charges engine ay 1amp when hooked up.
Been testing for 18 months and never gone done below 85%.
This charging of the leisure battery is also something we have been struggling with. A typical scenario is that the leisure battery is down to 50%, and you set off for a drive of 1-2h. When starting the engine, the leisure battery shows the same voltage as stationary, and the dra w -s -1 to -2 amps. Pressing the battery boost button does nothing but raise the idle revs to 1200rpm, the leisure battery is still not charged. After the 1-2h drive, the leisure battery charge rate is still at 50%. Then, occasionally and under pretty much the same circumstances the charge rate goes up to 70-80 ampere after starting the engine, effectively charging the leisure battery in less than an hour. I cannot figure out when the van decides to charge the leisure battery, and when not. Obviously there is some set of parameters controlling this, but can't figure out the "logic".
Not strictly true. When the engine is running the alternator is charging both batteries.
I have noticed same behaviour, it’s pretty fustrating
Yes, but only to 80%. So, you never have fully charged batteries unless on solar or hook up.
As is common on most leisure vehicles based on commercial base vehicles that are Euro 5/6 compliant.
The only way to get 100% chargers from the smart alternator is to disable the “ Smart “ function.
On the T5/6 this was done by switching on headlights or a heated seat. The T6.1 has a Max Chargers switch.
