Bent rear roof hinge / scissor
JMStockholm
JMStockholm
Sweden
T6.1 Ocean 150
Managed to bend the rear hinges when opening the rear hatch with a bicycle on the rack. So, what to do? Anyone having experience of fixing this, I search the forum but could not find the same issue discussed.
Sorry to hear that.
You could try straightening it but I think that would be quit difficult so you will probably have to replace it.
Will it be a garage repair or DIY?
I don't know if Insurance would be an avenue to explore.
Thanks, will check insurance tomorrow. If not covered I'll try the DIY route and leave the hinge with a shop to straighten it out, and see how that works out. However, there might be hidden complications with the scissor mechanism being under tension or something, looking for experience here.
If you are going down the DIY route, when removing the hinge I would support the roof from inside, when opened , to stop it dropping on that side BUT also have strap over the roof and under the vehicle to stop the roof going up due to the upwards pressure of the hydraulic cylinder that side when the scissor hinge is unbolted.
It should be fully opened? Can't do that in the garage, up to 1/3 I guess. Could it be closed again to drive back into garage without the hinge?
I would have thought it would/ should be fully open to remove the hinge and I wouldn’t try to close the roof until it is replaced. You could just leave it up with a Topper on or a tarpaulin over the roof.
Can’t find a price for rear hinge but the front is about £250 GB .
Do the scissors have any control on limiting the height, especially the rear ones? One thing is it will need a good plan to avoid further damage if a diy job. Good luck.
That's why I suggested a strap over the roof as well as a prop inside to stop the roof moving from its open position, either way.
I got the damage accepted by the insurance. EUR 800 in deductible so quite expensive misstake even so, but hopefully all will be good after the repair.
Thanks all for you input and help!
