Odd fridge problem
Milly
Milly
Knutsford
Hi
Bit of guidance please and apologies if this has been covered elsewhere.
My fridge was removed recently and reinstalled(non fridge issue)
I came to use the fridge over Christmas and the control panel light illuminated as normal (and stayed on)and I assumed all was well.
The fridge did not turn on
I have checked
1. No errors codes in the hidden menu
2.Batteries all topped up to 100%
3.All 10 amp red fuses intact
I am not sure what to check next and would be grateful for any ideas
What setting for thermostat used ?
Fridge may not work if room temperature is too low .
Hi
I have checked
Through the access hatch in the cupboard, check that all the electrical connections are pushed in and esp check the Red wire on the Fridge Relay (lowest black block with white label just P and T just visible - not yellow label )
Hi thanks
Just checked the wires and they seem pretty tight in
Photo for info
Getting to the extent of my technical knowledge now! but could the thermostat be malfunctioning?
Yes T 6 2019
Will get through the link and follow your advice
Thanks for all your help
