Sale!
Cali-WrapCali-WrapCali-WrapCali-Wrap
Comfortz VW California ‘Cali-Wrap’ – Thermal Roof Wrap
Cali-Wrap
Cali-Wrap
Cali-Wrap
Cali-Wrap
(8 customer reviews)
Price range: £249.99 through £374.99 Inc VAT
Comfortz VW California ‘Cali-Wrap’ – Thermal Roof Wrap. Here we have the new VW California Cali-Wrap from Comfortz Leisure. Fits the T5 & T6 SE, Ocean and Beach (The exception to this is 2005-2006 Californias, please call to discuss)
This insulated easy to fit wrap comes in various colours to make your California stand out from the crowd. It provides full black out for the roof of the California (With the T6 light is often an issue) and is also completely reversible with a reflective silver on the inside for the sunnier climates. As well as keeping the upstairs nice and warm we have also noticed a slight reduction in background noise from the campsite.
Fitting is a simple as wrapping the screen around the roof canvas of the California and fed behind the mechanisms and struts of the roof. The Cali-Wrap must be removed when lowering the roof and we have found that a small plastic stool (which can be kept in the tailgate with the chairs) helps with the fitting.
Great option if using solar panels on the roof or roof bars and boxes.
Available to choose with PVC Windows, Side Vents or with nothing at all , (SE / Ocean 3 windows – Beach / Coast 3 or 2 side windows)
If vents are chosen for an Ocean – this will come with 2 side vents and 1 PVC window in the front.
Key Features
Fully insulated
Waterproof
Offer a black out for the roof
Various colours
Easy to fit and remove
Reversible for hotter climate
Reduces noise
Pack Size – 20cm x 20cm x 107cm
Made to order please allow for 5 days for dispatch
Weight 7 kg
Dimensions 102 × 32 × 32 cm
Windows / Vents?
Nothing, PVC windows, Side vents No PVC Front Window, Side Vents Plus Front PVC Window
Colour?
Black, Royal Blue, Forest Green, Light Grey, Mid Grey, Purple, Maroon, Yellow, Red, Navy Blue
Model
Beach 2 Side Windows, Coast 2 Side Windows, Coast 3 Windows, Ocean 3 Windows, Beach capmer 3 Windows
Comfortz Leisure
Comfortz Leisure is a small family run business specialising in custom-made accessories for your VW California, campervan or caravan.
Reviews (8)
8 reviews for Comfortz VW California ‘Cali-Wrap’ – Thermal Roof Wrap
  1. Paul Briody (verified owner)
    Easy to install and provides good insulation against wind and rain. Disappointing that there is no cover to put across the window when not being used which means you dont get a blackout when trying to sleep. Other makes have an insert which slides in between the campervan layer and the roof rap and I wrongly assumed this product would have the same. Hence 3 stars
  2. Steven Hagger (verified owner)
    Really Nice Cover. I like the clear plastic window at the front so you can see out in the rain. The side vents to let a bit of air in on the sheltered side is good too. The vertical poles at each corner make.it much easier to fit than a cover I had without. Overall very pleased.
  3. Heath Arnfield (verified owner)
    Arrived in very good time and for a first time user simplicity itself to set up. I would hazard a guess at 10 minutes at most.
    Thermal efficiency is great and it also dampened down some site noise a little. It just means we can extend the camping season for longer every year now!
  4. Adrian Allsopp (verified owner)
    I bought the cover without windows or vents (wanting a black-out effect too), and was pleased with the ease of installation and fit.
    The stiffening poles improve the fit, but make storage bulkier.
    It performs well, but perhaps because mine is without vents it does gather a little condensation.
    So, in hindsight, vents would be preferable.
  5. mattsv (verified owner)
    Easy and quick to fit (with a small step-stool) and makes the pop top much warmer in the winter, darker and quieter – also keeps it dry. Nice to have the flaps open in the day (especially when raining to let light in). Highly recommended.
  6. Alan Andrews (verified owner)
    Bought without windows, as saw no value in windows opening without compromise to thermal efficiency. Was used on T6 Ocean during Storm Ciaran (Oct/Nov 2023).
    Certainly improves the thermal efficiency of having the roof up at this time of year.
    Installed over the roof side mechanism as used with additional roof topper. This certainly made installing easier.
    Comes as 4 separate thermal panels…. Front (attached with velcro to sides), Sides (these have rigid bar at each end that ensures the panel fits tightly), and rear. The rear has no velcro, and seems to be fitted under 2 bungees from one rear corner to the other. With a rear vw bike rack it was very awkward to fit the rear panel and the 2 bungees, s we chose to not install the rear panel.
    The thermal wrap provides a very good black-out.
    Improvements:
    1. The attachment of the 2 bungees is awkward and is unclear why the fastening is manufactured this way
    2. Consider using velcro for the rear like is provided for the front.
  7. Ian Butterworth (verified owner)
    We used our new Cali wrap during a recent week away. I fitted the wrap on my own without any problems using a short I.4m telescopic ladder. Initially I found the bungee Hooks and eyelets difficult to undo but this has become easier. Once in place the wrap has provided good blackout, insulation and soundproofing. The fit and quality is good. We had good weather most of the time so didn’t have to fit or remove in the rain.
  8. Michael Grainger (verified owner)
    Ordered December 2025 without any windows or ventilation for a cold trip before the new year.
    Seems to be warmer in the van compared to not using it, and slightly less noise.
    Fits perfectly and glad I made the purchase. Although haven’t experienced any bad rainfall or a stormy weather but can’t see there being any problems with it. Very well made
Add a review
You may also like…
  • Kampa Hottie Lightweight Portable Gas Heater – 2kw
    Original price was: £42.99.Current price is: £29.99. Inc VAT
  • Comfortz VW T5 T6 & T6.1 California SE/Ocean Mattress Topper
    Price range: £99.99 through £119.99 Inc VAT
    View product
  • Deluxe 3-Piece Carpet Full Set for VW California Ocean T5/T6 – Black
    Original price was: £159.99.Current price is: £109.99. Inc VAT
    View product
  • VW T5 T6 T6.1 ‘California’ Embroided Step Mats – 3 Piece Set – Black
    Original price was: £26.99.Current price is: £22.99. Inc VAT
