Dometic Cl 42 Cool Ice Stone Insulation Cooler Box – 42L
Dometic Cl 42 Cool Ice box Insulation Cooler Box 42L Stone
£269.00 Inc VAT
Out of stock
Email Me When Back in Stock
This highly efficient and lightweight icebox can keep ice for several days. With its thick refrigeration grade foam insulation and unique labyrinth seal design, you can take ice cold refreshment with you – wherever you’re going!
Easy access and user-friendliness are at the forefront of the new Dometic Cool-Ice iceboxes’ design. The new series of icebox accessories improve comfort while travelling, keep your icebox secure in a variety of locations, better organise your food and beverages and even provide somewhere to hold your drink or fishing rod! A seat cushion is available for each of the new Dometic Iceboxes, which is easy to attach and detach and provides a comfortable seat when catching fish or travelling by boat. Baskets and dividers are available to help organise the contents of your Dometic icebox; avoid contamination by placing your fishing bait in one section and your lunch in another. Finally, a series of accessories have been developed that can be fitted in to the handle of the new Dometic iceboxes. The lightweight and easy-to-install bracket can hold up to two drink holders, rod holders or bottle openers. Mix and match these excellent accessories as you see fit!
High outside temperatures, uneven terrain, dust and mud? The Dometic iceboxes will take this in their stride. The Cool Ice boxes are equipped with extremely effective insulation, and once the cool packs or ice cubes have been placed inside, they will keep groceries, fish, bait and wild game fresh. Depending on use and weather conditions, this can be for several days at a time. Ultimately, every single detail of these boxes, made from impact-resistant and seamless plastic, is designed for the toughest conditions. This trusty icebox comes with strong and thick refrigeration grade foam insulation with unique labyrinth seal design that holds the cold air inside and hot air out for longer. This ensures your ice lasts much longer, despite the outside temperatures.
If possible, store the Dometic iceboxes in cool surroundings for several hours before use and keep them out of direct sunlight. If being filled with drinks or groceries, we recommend chilling the items beforehand. Standard freezer packs or ice cubes are suitable as coolants. Air will compromise the cooling capacity and shorten the duration of cooling. Therefore avoid opening it unnecessarily and pack the boxes as full as possible.
  • Highly effective insulation, extremely low heat absorption
  • Highly effective labyrinth seal
  • Made without seams from UV-resistant plastic, easy to clean
  • Integrated tie-down points
  • Optimised volume/weight ratio
9600000541
Weight 33.8 kg
Dimensions 525 × 520 × 930 cm
Dometic
Offer smart and reliable products for people who enjoy outdoor activities enabled by a car, recreational vehicle, or boat.
Kampa Dometic
Dometic make the world more mobile. Their motivation is to create products with outstanding design for use in recreational vehicles.
Be the first to review “Dometic Cl 42 Cool Ice box Insulation Cooler Box 42L Stone”
£269.00 Inc VAT
Subtotal: £44.99
View basketCheckout
