Vango Arden Lightweight Tailgate Awning - 2025 (180-210cm Van Height)
Vango Arden Lightweight Poled Tailgate Non-Driveaway Awning – (180-210cm)
£229.00 Inc VAT
In stock
Vango Arden Lightweight Poled Tailgate Driveaway Awning – (180-210cm)
Designed for couples and independent travellers with the ‘Spirit of Adventure’ to quote Vango.
With a quick pitching time and ideal for short stops, the Vango Arden is a lightweight, easily adjustable Tailgate Awning/Tent which adds extra outdoor space to the rear of your vehicle.
With a height range of 180-210cm, the Arden is specifically targeted at Low-Height Campervans and SUV Vehicles (ideal for VW Transporters, Californias, Marco Polo, Ford Custom/Nugget, Citroen Holidays etc)
Requiring only one pole, the Arden includes width and height adjustments that neatly fit onto the rear of your vehicle by using one of the four attachment methods.
Vango’s reliable and lightweight Sentinel Active 75D Fabric, ensures a compact pack size, easily stored within your vehicle.
Not only is the Vango Arden a tailgate awning, but it can also be used on the side of the vehicle!
Why not pair with Vango’s Steel King Poles to turn the door into a canopy?
  • Sentinel Active 75D – Lightweight, compact and waterproof. 75D fabric with an HH rating of 3,000MM.
  • Multiple Vehicle Attachment Methods – comes with pre-attached 6mm kador, 8M over vehicle straps, roof bar attachment tabs and a sleeve for the pole & clamp kit system.
  • Diamond Clear Windows – Maximise light and visibility to provide a bright and airy environment
  • Mesh Front Door – Fitted with internal mesh fly screen for bug-free ventilation
  • Easy Pack Carry Bag – Oversized carry bag to make it easier to pack the awning away
  • Toggled Privacy Curtains – Easy to use privacy curtains that can be simply rolled away when not in use
  • Fully Wind and Rain Tested – Tested with wind and heavy rainfall to the European standard EN5912
  • Supplied with Steel Pegs – Strong and durable pegs ideal for grass pitches. Supplied with a handy carry bag
  • Touring Awning – designed for touring use; it is not designed for static or long-term seasonal pitching, as extensive exposure to UV light will cause accelerated fabric degradation. UV degradation is not covered under the warranty.
  • Vango PowerFlex Fibreglass Poles – Creates strong, light and reliable structures
  • LinkedIn Groundsheet – This groundsheet can be attached or detached from the living area, making it easier to clean
  • Clear Visibility Guylines – Bright coloured guylines for clear visibility to prevent tripping hazards and ensure stability in high winds.
  • Key pegging points are highlighted in orange.
  • SkyTrack II – A flexible hanging system which allows you to easily attach lighting or storage
  • Awning is multifunctional and can be pitched on the side or rear of your campervan.
Specifications
  • Weight 7.9kg
  • Pitching Time 5mins
  • Kador Length 210cm
  • Kador Height 180-210 (Low)cm
  • Connection Width 120-190cm
  • Pack size (Bag 1) L55.0 x H22.0 x W24.0cm
  • Footprint at widest point – 285cm x 260cm
AWVARDNTG000001
Vango
Be the first to review “Vango Arden Lightweight Poled Tailgate Non-Driveaway Awning – (180-210cm)”
£229.00 Inc VAT
