Vango Tailgate Hub II Low Tailgate Driveaway Awning – Poled – 2025 (180-210cm)
With a van height of 180-210cm, the Vango Tailgate Hub II is ideal for couples or independent travellers, or simply just to add an extra outdoor space to the rear of your vehicle.
Suitable for a wide range of low-height vans and SUV’s.
The perfect quick pitch for short stops, the Tailgate Hub has been designed with active adventurers in mind.
Effortless attachment requires only pegging straps at the front of the vehicle and tunnel area, allowing the awning to fit neatly to your vehicle without the need for kador rails. However, should you wish to use them, the traditional attachment options of roof bar attachment tabs, kador and a sleeve for pole and clamp are also included.
Two doors in the connecting tunnel make for a convenient storage area, while Vango’s reliable and lightweight Sentinel Active 75D Fabric, ensures a compact pack size, easily stored away when not in use.
The Tailgate Hub does not require the tailgate to be open to support the structure, so you can simply roll away the connecting tunnel should you want to drive off and explore for the day. Be ready for any adventure with the Tailgate Hub.
Not only is this a Tailgate Awning, it can also be used as a normal driveaway to the side of your vehicle!
- Sentinel Active 75D – Lightweight, compact and waterproof. 75D fabric with an HH rating of 3,000MM.
- Easy Access Doors – A flat entry access door creates easy access for wheelchairs, prams and people with reduced mobility
- Mesh Front Door – Fitted with internal mesh fly screen for bug-free ventilation
- Diamond Clear Windows – Maximise light and visibility to provide a bright and airy environment
- Toggled Privacy Curtains – Easy to use privacy curtains that can be simply rolled away when not in use
- Two Doors in Tunnel Attachment to Vehicle – For convenient access to the front or back of your vehicle
- SkyTrack II – A flexible hanging system which allows you to easily attach lighting or storage. The SkyTrack system allows you to customise your awning to suit your needs
- Tunnel Adjustment Strap – Helps collect any excess material and creates a neater looking tunnel and a tighter fit to the vehicle
- Roll Away Connecting Tunnel – Detach your awning when you drive away for the day, simply roll back the tunnel and toggle it to secure
- Supplied with Steel Pegs – Strong and durable pegs ideal for grass pitches. Supplied with a handy carry bag
- Lantern Hanging Points – Conveniently positioned to attach your light(s) with ease
- Easy Pack Carry Bag – Oversized carry bag to make it easier to pack the awning away
- Fully Wind and Rain Tested – Tested with wind and heavy rainfall to the European standard EN5912
- Touring Awning – This awning is designed for touring use; it is not designed for static or long-term seasonal pitching as extensive exposure to UV light will cause accelerated fabric degradation. UV degradation is not covered under the warranty.
- Linked-In Groundsheet – This groundsheet can be attached or detached from the living area making it easier to clean
- Drive Away – Using the addition of a Drive Away Kit, detach the tunnel area of your awning from your vehicle and roll it away, leaving your awning free-standing as you explore for the day.
- Clear Visibility Guylines – Bright coloured guylines for clear visibility to prevent tripping hazards and ensure stability in high winds.
- Key pegging points are highlighted orange. Pitch these points first to create the correct shape of your awning. Thereafter errect your tent.
- Awning is multifunctional and can be pitched on the side or rear of your campervan.
- Innovative system allowing for the awning to attach to a range of low height vehicles with width ranging from 120-190cm using adjustable tension straps.
Specifications
- Weight 11.4kg
- Depth 250.0cm
- Height 215.0cm
- Width 250.0cm
- Pitching Time 8mins
- Kador Length 210cm
- Kador Height 180-210 (Low)cm
- Fabric Sentinel A
- Connection Width 190cm
- Pack size (Bag 1) L70.0 x H280 x W30.0cm
- Bag Weight 10.4kg
- Rail Weight 5.6kg
AWVTAILGA000001
Check out the Vango Arden Tailgate Awning HERE
Frequently bought together
£399.00 Inc VAT
![outdoor-revolution-cayman-cuda-fg-2024-towsure-2[1]](https://vwcaliforniaclub.com/shop/wp-content/uploads/2023/09/outdoor-revolution-cayman-cuda-fg-2024-towsure-21.jpg)
