Sale!
Vango Cove II Low Poled Drive Away Awning
Vango Cove II Low Poled Drive Away Awning – 2024 Version
Original price was: £499.99.Current price is: £359.00. Inc VAT
Out of stock
Email Me When Back in Stock
Vango Cove II Low Poled Drive Away Awning.
Perfect for couples and young families, the Cove is a compact awning that provides valuable extra space on weekends away. Featuring lightweight Powerflex poles and Vango’s Sentinel Active fabric ensuring a compact pack size leaving you with more room in your campervan for your camping essentials. With space to clip in a Drive Away Awning Bedroom should guests come to stay and a pre-attached front canopy, this versatile drive away awning will be a staple to expand your liveable space on any trip. Featuring a front-facing layout, the Cove is positioned the same way as your campervan, ensuring you are always facing the view and giving you added privacy from your campsite neighbours. The ideal addition to your campervan for wherever your next adventure takes you.
  • Easy Access Doors – A flat entry access door creates easy access for wheelchairs, prams and people with reduced mobility
  • Two Doors in Tunnel Attachment to Vehicle – For convenient access to the front or back of your vehicle
  • Diamond Clear Windows – Maximise light and visibility to provide a bright and airy environment
  • Toggled Privacy Curtains – Easy to use privacy curtains that can be simply rolled away when not in use
  • Easy Pack Carry Bag – Oversized carry bag to make it easier to pack the awning away
  • This awning has multiple additions available for enhanced functionality – Please check our additions table for more details
  • Tunnel Adjustment Strap – Helps collect any excess material and creates a neater looking tunnel and a tighter fit to the vehicle
  • Supplied with Steel Pegs – Strong and durable pegs ideal for grass pitches. Supplied with a handy carry bag
  • TBS®II Tension Band System – Ensures awning performs in adverse conditions, especially in strong, changeable winds. When tensioned, the bands brace the beam or pole at 3 points and prevent sideways movement. Adjust TBS®II to remove slack. Do not over tension, as this may deform the poles. Can be stowed away in calm weather
  • AirZone™ Ventilation – High and low level ventilation panels combine to create a comfortable flow of air throughout the awning, which is essential for reducing condensation
  • High Visibility Guylines – High visibility lower half to prevent tripping hazards and ensure stability in high winds
  • Lantern Hanging Points – Conveniently positioned to attach your light(s) with ease
  • Roll Away Connecting Tunnel – Detach your awning when you drive away for the day, simply roll back the tunnel and toggle it to secure
  • Side Attachment – Awning attaches to your van with a side attachment to ensure you are always facing the view wherever you go
  • Multiple Vehicle Attachment Methods – All our awnings come with pre-attached 6mm kador, 8M over vehicle straps, roof bar attachment tabs and sleeve for pole & clamp kit system. This ensures our awnings are compatible with any vehicle
  • Touring Awning – This awning is designed for touring use; it is not designed for static or long-term seasonal pitching as extensive exposure to UV light will cause accelerated fabric degradation. UV degradation is not covered under the warranty. However, under normal holiday use your awning will give long service
  • Fully Wind and Rain Tested – Tested with wind and heavy rainfall to the European standard EN5912
  • Mesh Front Door – Fitted with internal mesh fly screen for bug-free ventilation
  • Pre-Attached Front Canopy – Provides shelter from all weathers and is ideal for socialising
  • Vango PowerFlex® Fibreglass Poles – Creates strong, light and reliable structures
  • Sentinel Active Fabric – When pack size and weight are the key influencers in choosing your awning, our specifically designed Sentinel Active fabric will surpass your needs. Sentinel Active is strong, while being fully waterproof, ensuring great quality and performance coupled with compact pack sizes
  • Sewn-in Groundsheet – Provides a bug and draught free environment. Groundsheet is attached to the flysheet with an external storm skirt to give all-round protection
  • Drive Away – Using the addition of a Drive Away Kit, detach the tunnel area of your awning from your vehicle and roll it away leaving your awning free-standing as you explore for the day. Keep a note of your parking position for when you return and re-attach the awning to your vehicle
Specifications
  • TOTAL WEIGHT-13.2kg
  • PACKSIZE-L75.0 x H29.0 x W29.0cm
  • AWNING SIZE-Low
  • PITCHING TIME-10 mins
  • KADOR ADJUSTABLE HEIGHT-180-210cm
  • CARRY BAG WEIGHT-13.18kg
  • KADOR LENGTH-260cm
  • CANVAS/FABRIC WEIGHT-6.7kg
  • RAIL WEIGHT-6.7kg
AWSCOVEPO000001
Vango
Be the first to review “Vango Cove II Low Poled Drive Away Awning – 2024 Version”
Subtotal: £72.99
View basketCheckout
