Vango Sunlight AIR Canopy / Awning LOW 180-210cm
£409.99 Inc VAT
Out of stock
Email Me When Back in Stock
Vango Sunlight AIR Canopy / Awning LOW, this can be used as an enclosed fixed awning or the front and sides can be zipped off to create an open sun canopy for your campervan. The Sunlight has a single AirBeam tube allowing it to pitch in seconds with a lightweight but durable 150D Sentinel Active Fabric for a compact pack size.
This Sunlight Canopy can slide directly into a campervan awning rail or has the option to connect with throw over straps and velcro roof bar tabs. The removable sides and front can be zipped in to provide additional protection from the elements whilst still providing a view out with the large diamond clear windows.
For privacy at night or storing kit when out for the day, all windows have zipped curtains and there is a removable internal groundsheet ideal for when the ground is wet.
Please Note: This awning IS NOT designed to be used as a Drive-Away Awning
- 150D Fabric is lightweight, durable and waterproof with an HH rating of 4,000MM. Benefits from ColourLok™ Eco technology to aid colour retention.
- Inflatable AirBeam® Structure using market leading technology for pitching in a matter of minutes with supplied manual pump.
- Diamond Clear Windows help maximise light and visibility to provide a bright and airy environment.
- Removeable zipped doors allow awning to adapt to a sun canopy or provide shelter from the wind.
- Zipped Privacy Curtains are quick to use and allow varying levels of opening.
- Removable Groundsheet can be used depending on conditions.
- Multiple connection options including kador strip, throw over straps and Velcro roof bar tabs.
- Adjustable Pegging Points allow awning to be pitched perfectly on uneven surfaces
- AirBeam® Pump allows you to effortlessly inflate your AirBeam® product.
- Supplied with Steel Pegs – Strong and durable pegs ideal for grass pitches.
- Includes double action hand pump and carry bag
Specifications
- Vehicle Connection Height: LOW – 180cm to 210cm
- Kador Connection Length: 260cm
- Pack size: 75cm x 28cm x 28cm
- Weight: 10kg
- Frame: 1 x AirBeam
- Fabric: Fabric: Sentinel Active 150D 4,000mm HH
AWVSUNLIG000002
| Weight | 10 kg |
| Dimensions | 70 × 30 × 30 cm |
