VW California
Caravan
Drive-Away Awnings
Tents
Vango Tolga Low Air Drive Away Awning
Vango Tolga Low Air Drive Away Awning – Shadow Grey
£499.00 Inc VAT
Only 1 left in stock
Vango Tolga Low Air Drive Away Awning, Ideal for Campervans VW T5 T6 T6.1 California, Marco Polo, Transit Nugget, Vivaro, Traffic, Transporter
The Tolga Air awning is quick & easy to erect with a pitching time of only 8 minutes.
The Tolga awning is designed for the new VW, Bongo and Mercedes Marco Polo size campervans and conversions with a height of 180cm-210cm. Using Vango’s AirBeam® Technology Tolga is simple and fast to inflate, combined with Sentinel Sport fabric which is strong durable and waterproof and uses ColourLok technology to reduce the effects of UV. A handy covered entrance allows additional living space outside your awning, whilst the SkyTrack II® System is perfect for hanging lights and adding a SkyLiner to reduce condensation and provide a thermal barrier. This drive away air awning has a great weight to space ratio ensuring you have all the room you need to enjoy your camping trips whilst still being light-weight and compact to combat the limited storage space often found in a campervan. Enjoy every adventure with the Tolga campervan awning, for wherever you go
  • Vango AirBeam® – Quick to pitch and creates a strong and rigid structure
  • Fully Sewn-in Groundsheet – Groundsheet is attached to the flysheet with an external storm skirt to provide a bug and draught free environment
  • Low level vents – Helps circulate air within the awning and reduces condensation
  • AirSpeed® Valve System and easy access positioning – Designed by Vango to inflate your AirBeam®s with even less effort
  • Pre-angled Beams – Achieve greater internal space than with a standard curve. Provides effective bracing against winds
  • AirSpeed® Valve – Simple system with easy access positioning to inflate your AirBeams® with even less effort
  • Patented Vango TBS®II Tension Band System ensures awning performs in adverse conditions, especially in strong, changeable winds. When tensioned, the bands brace the pole at 3 points, and prevent sideways movement. Adjust TBS®II to remove slack. Do not over tension, as this may deform the poles. Can be stowed away in calm weather
  • Bracer beams included – Designed to fit in between the awnings main AirBeams® to enhance stability in high winds
  • SkyTrack® System – Attachment system which can be used to attach lighting, tidy cables or even hang additional storage units
  • Webbing storm straps – Provides secure guying at the front and rear of the awning
  • High Visibility Guylines – High visibility lower half to prevent tripping hazards and ensure stability in high winds
  • Adjustable Pegging System – Allows awning to be pitched perfectly on uneven surfaces
  • Diamond Clear Windows – Maximise light and visibility to provide a bright and airy environment
  • Zipped Privacy Curtains – Simple and quick to use, allowing varying levels of opening. Fitted to the flysheet with no gaps that simply rolls down into a pocket
  • Diamond Clear windows – Maximise light and visibility
  • Zipped privacy curtains – Simple and quick to use, zip curtains allow varying levels of opening or simply roll down and secure away.
  • Covered Entry – Gives a sheltered entrance into your awning, which prevents rain from dripping into the living area
  • Door in connecting panel – Allows convenient access
  • Flat Entry Groundsheet – Easily dropped to ground level allowing effortless entering without needing to step over the entrance
  • Two Doors in Tunnel – For convenient access to the front or back of your vehicle
  • Roll Away Connecting Tunnel – Quick and easy when you drive away for the day, simply roll back the tunnel
  • Mesh Front Door – Fitted with internal mesh panel for bug-free ventilation
  • Low Level Ventilation – Helps circulate air within the awning and reduces condensation
  • Fully taped seams – All flysheet and groundsheet seams are factory taped which provides a watertight seal
  • Supplied with Pack of 10 Skyhooks – Simply slide on to the SkyTrack® System to hang storage or lights
  • Optional bedroom inner – Optional extra available to purchase separately
  • Cable entry point with tidies – Zipped entry point for power cable, with touch fastener tidies
  • Multiple Attachment Methods – Pre-attached 6mm kador, over vehicle straps, roof bar attachment tabs and sleeve for pole & clamp
  • AirAway® Vehicle Awnings included with – Pre-attached 6mm kador strip, over vehicle webbing straps, roof bar attachment tabs, sleeve for pole & clamp, steel rock pegs & mallet with carry bag, easy pack carry bag and double action pump with carry bag
  • SkyLiners included – Reduces the effects of condensation and provides a thermal barrier in cold weather
  • Lantern Hanging Points – Conveniently positioned to attach your light(s)
  • Fire retardant fabrics – Meets European EN5912 safety standard
  • Fully wind and rain tested – Weather tested to the European standard EN5912 by certified test centre
Specifications
  • Weight: 17.6kg
  • Floor size:185cm living space by 320cm Tunnel size : 135cm
  • Packsize: L75.0 x H35.0 x W36.0cm
  • Kador Adjustable Height: 180-195
  • Weight without Accessories: 12.15kg
  • Colour : Shadow Grey
AWQTOLGA S32A3G
Vango
Be the first to review “Vango Tolga Low Air Drive Away Awning – Shadow Grey”
You may also like…
  • Vango Drive Away Awning Kit 6mm to 6mm (3m Length)
£499.00 Inc VAT
Discount Code - SALE10
    SUBSCRIBE
