VW California Fridge Trivit – Wine Bottle Holder Version
£44.99 Inc VAT
In stock
SKU: 5060641651653 Category: Tag:
If you own a VW California Ocean & SE, which comes with a factory-fitted fridge, then the VW California Fridge Trivit is a must-have addition!
Perhaps you’ve noticed that on occasion, if not regularly, water often pools in the bottom of the fridge and can damage your produce which is inconvenient and frustrating.
The fridge trivit helps with circulation and prevents items from getting damp from moisture, meaning you can enjoy your break without having to worry!
Simply pop the trivit into the bottom of your fridge, the folded lip towards the bottom and it will rest against the ledge already in there.
No need to worry about its stability, the fridge trivit is a tried and tested, much-loved product that can hold a substantial amount of produce.
The wine bottle holder version comes with two snazzy holes which are the perfect fit for wine bottles.
Please note: the trivit is made from clear plastic, in the first two images there is a protective film that needs removing when you receive your item!
Also available is the standard version here
Type
Wine Bottle Holder Version, Standard Version
Be the first to review “VW California Fridge Trivit – Wine Bottle Holder Version”
£44.99 Inc VAT
Subtotal: £986.86
View basketCheckout
