12v Inverter help required
Moose
Moose
T6 Ocean 204 DSG
London
T6 Ocean 204
Can anyone recommend a good 12v Inverter of at least 500 watts to charge the Swytch batteries for our Bromptons, so many out there from £41.00 from Toolstation (good reviews) to £165.00 for a Victron.
Need to be able to change either whilst travelling or not on hook up, we do have 2 of Rogers Solar panels fitted.
Any advise greatly appreciated.
I went with a Victorian 500.
Post in thread 'Charging electric longboards'
https://vwcaliforniaclub.com/threads/charging-electric-longboards.19841/post-445943
Even with the twin solar panels. Keep an eye on things if charging two batteries at the same time when not driving. My board can pretty much drain the two AGM batteries if I charge it from around 20%.
The Victron is expensive and has a good reputation. I put in a permanent Anderson plug under the left hand seat and store the alternator unplugged under the right hand seat when not in use. It’s fairly bulky but doesn’t get hot using it for what I do.
There is a long thread here that has additional commentary on the options if you have the time.
Hello
I have the same bike, camper and solar set up - what inverter did you purchase and do this charge the Brompton without issue?
Best wishes, Kirstie
Haves1979
egena
E
Dodge1311
Legin
L
D
7K
erik.godderis
erik.godderis
Tom Rae
14K
altvic
altvic
