Out of interest, where were your zips positioned (if you can remember?). Seen a reference somewhere to suggest the zips shouldn't be at either end of the zip run. Ours got a fair bit of side-rain (albeit it was at an angle, not direct) over the weekend in lashing rain and no ingress, at least nothing I could see.First wet trip in our MY23 this weekend and after a couple of hours sheltering in a coffee shop returned to the van to water dripping heavily along the whole left hand side of the living accommodation. My impression was that it was the seam at the bottom of the netted window that was the problem - it was heavy driving rain for several hours before we returned to the van, directly at that side of the van.
Van was on a slight incline to the rear so water had collected in the rear corner of the upstairs bed (wet mattress) down through the rear cupboard (wet clothes) and cascading off all 3 lights above the sink etc. with a good half cm of water collected in the corner of the hob (pic) - glass was closed but had pooled on top and run through the gaps.
Seemingly we are dry again now but who really knows how much got behind the kitchen paneling, ceiling lights, etc.
It really was extreme weather but even so never had it come through the seems like that in any of the multiple tents that we have used over the years. will report to VW this week as would be nervous to leave the roof up again in rain.
I hasten to add the conditions I was in and the orientation of the van meant very little rain would have landed on the front of the bellows - perhaps why? I am almost dreading a "still" rainy day now . . .While I haven't experienced any leaking myself and said as much previously with caveat that the rain I experienced was light, I have yet to hear anyone else say their MY23 bellows were water tight.
Had same with mine & same solution!Can’t help with the canvas, but I had a slight leak from the top tailgate seal. Try gently pulling it away from the bodywork all along the top so It seals against the tailgate better.
You don't have a right to reject a new vehicle just because you've heard on the internet that there is a possibility that there may be a leaky roof.I am going to whisper this!
And knowing this! Why take delivery of one? Just causes a knock on affect of more problems! Also VW won’t do anything because they are still selling them!
Ps: as anyone heard of roof bellow problems on Vw converted vans?
Hence my comment on newish members coming on here just for this issue and yelling at other members trying to help them out. Direct your ire to VW. Not to the folks here trying to give sage advice. There are three points in this reply here, ignoring the shouting, that are factually incorrect. To detail why you are wrong is a step too far on a Monday and you’ll just yell back with lots of !!!!!!!!!Ah!
I thought the issues posted on this site and reported to Vw are real life factual issues! Didn’t realise that they were just made up for perusal?
Yes! You can legally reject an item if it is not fit for purpose!
Cool, calm, considered and action focused.I have booked my new Ocean in for a bellows change following the leaks from the front panel seams which I posted above. I couldn't get a date earlier than 19 September at Yeomans Exeter due to a combination of needing a courtesy vehicle, them wanting their master technician to do the work and Yeomans being rammed with work from the former Snows van centre in Plymouth. I am content with this as I hope that it allows VW to come up with a proper fix and in the meantime I have logged this warranty issue.
I also think that the leaking is because of rain getting into the netting over the windows and sitting at the bottom seams long enough for capillary action to take water through the larger stitching holes to the inside surface. I would be happy to try waterproofing the seams but I want VW to do this to avoid any warranty arguments later if it doesn't work.
I am happy to put my name forward for any group action but I think it will need hundreds of names before VW change strategy for dealing with this problem. Before I take my van in I will check with Yeomans that there is a new or altered bellows as I don't see the point in just having an identical bellows fitted for the reasons mentioned by others here.
The way these issues work is the warranty team usually has a series of engineers looking at the data passed back to them for potential large issues. This data comes from the repairs that are approved or passed back to VW UK for review which then have to go back to VW DE. At Nissan it was easier and quicker as we were all UK based including design, engineering and UK HQ. At any point in time the team will have 30 - 50 things they are watching.My concern is just replacing the part on the assumption it's a manufacturing defect, as opposed to a design flaw, will just result in the same problem again. Assuming it is a design flaw (which it does sound like) then the only way the "fix" will change will be if VWCV accept there's a flaw, produce a bona fide fix and roll it out to their network. Until such time, any dealer will operate on the assumption it's a defective part and replace like for like. Rinse and repeat if you'll excuse the pun . . .
Until you've taken delivery & established that your roof leaks how do you know its not fit for purpose?Yes! You can legally reject an item if it is not fit for purpose!
I am in the unlucky position of having elevating roof seal early corrosion (separately posted), but in the lucky position (as I see it) of having a MY2023 with the previous bellows fabric. For what it is worth, if I was taking delivery now, I would try (either by delivery refusal or an early water penetration warranty claim) to get agreement to exchange the bellows to the previous material, if/whilst there are stocks remaining - just for immediate peace of mind and dryness.Don’t be judgmental, opinionated, assuming and disrespectful it doesn’t achieve anything?
Just be factual!
Back to the thread!
Isn’t this a case of Deja Vu?
The rusting roof issue we have put up with for many many years!
Vw haven’t rectified this, so I don’t think the water ingress will be priority!
The T7 will be!
Andy here are some pictures for you, all from outside
LOL sorry mine is a 2021 so old single layerThanks
Is that the new 2 layer or old single layer?
Looks like the new double layer fabricThanks
I would but its lashing down here so don't want to put the roof up at the moment.Looks like Trojax answered and my assumption was incorrect. Can anyone post a closeup of the new fabric for comparison, inside and out.
This post from Breeze Tom suggests VW are aware abs working on it. Surely they’ll just make the manufacturer of the bellows design a replacement? I’ll see how my MY2023 does in the rain and report back.So just speaking to Tim here at the Van Centre in regard to this we believe Volkswagen are aware of this issue.
What we can’t say that vehicles that have recently been built are 100% affected by this.
We had ordered a few bellows as stock for ongoing issues we have that Volkswagen have recalled. This is the most amount of info we have.
