![Trojax](/data/avatars/m/34/34360.jpg?1680020790)
Trojax
That's Just plane FUNNY lmaoI would but its lashing down here so don't want to put the roof up at the momen
Take paper towels and plenty of cloths with youThis post from Breeze Tom suggests VW are aware abs working on it. Surely they’ll just make the manufacturer of the bellows design a replacement? I’ll see how my MY2023 does in the rain and report back.
See my previous post. Might not be a design fault, might be installation. Might not be installation might be manufacture. Might not be manufatcure might be parts.This post from Breeze Tom suggests VW are aware abs working on it. Surely they’ll just make the manufacturer of the bellows design a replacement? I’ll see how my MY2023 does in the rain and report back.
You’ve missed the point I was making. Tom says VW recalled the bellows they had in stock so VW obviously think there is or could be an issue with them. This surely means they can’t deny a warranty claim, plead ignorance or that it’s a single one off case of failure for anyone who has an issue. We don’t know why they’ve recalled them but it suggests there’s an issue of some kind with them. If not the leaking issue then what else could it be? Too much of a coincidence for me to believe it’s for another reason.See my previous post. Might not be a design fault, might be installation. Might not be installation might be manufacture. Might not be manufatcure might be parts.
Might be material type. Thread type. Sewing tension. Needle size. Parts batch. Roof tension. Cut out hole size. Lack of run off. Too much run off.
That all needs to be worked out first so you can get a root cause to fix. The bellows might be in house. Might be outsourced. The whole roof might be made offsite. The parts may arrive onsite and be fitted by VW staff. The amount of permutations are boggling.
I recall we had an issue once with door inners falling off. Was it adhesive? Parts? Fitting? Door shutting too hard? Screws? After 6 months it was discovered to be one operator at the supplier had his own glue pot he had made and would swap it out on his shift only. Took 6 months to work it out. Cost 10's of thousands in warranty repairs.
Missed that bit at the end of Toms mail, clunky sentence. In which case my explanation post remains correct and also means if they have got to the stage of recalling in stock parts are in fact working their way towards a solution. Could point to it being a parts issue (so design or parts failure) rather than factory fitment.You’ve missed the point I was making. Tom says VW recalled the bellows they had in stock so VW obviously think there is or could be an issue with them. This surely means they can’t deny a warranty claim, plead ignorance or that it’s a single one off case of failure for anyone who has an issue. We don’t know why they’ve recalled them but it suggests there’s an issue of some kind with them. If not the leaking issue then what else could it be? Too much of a coincidence for me to believe it’s for another reason.
Given the seriousness of water infiltration, and that most if not all bellows are affected, I wonder if this would warrant a proactive recall situation.Missed that bit at the end of Toms mail, clunky sentence. In which case my explanation post remains correct and also means if they have got to the stage of recalling in stock parts are in fact working their way towards a solution. Could point to it being a parts issue (so design or parts failure) rather than factory fitment.
I don't think anyone is saying that VW would not honour a warranty claim, are saying it's a one off or pleading ignorance, in fact from responses here seems quite the opposite.
I doubt it, it's not safety related, No point until they have a solution.Given the seriousness of water infiltration, and that most if not all bellows are affected, I wonder if this would warrant a proactive recall situation.
Agreed - full Warranty recall is usually reserved for safety issues. In general the rest are left to "when it comes in for a service" or "when the customer complains" - esp if it is intermittent.I doubt it, it's not safety related, No point until they have a solution.
That would be the cheapest solution for VW so I am sure it is something that is/will be investigated. It depends if the other seams also leak. I think I read at least one person reporting a leak through other (vertical ) seams too.i wonder if the issue could be solved by simply running a line of seam sealant down between the mesh and the roof fabric where they are stitched together?
I think they were both at the top - definitely weren’t at either end of the zip run as had always thought that was more suspect.Out of interest, where were your zips positioned (if you can remember?). Seen a reference somewhere to suggest the zips shouldn't be at either end of the zip run. Ours got a fair bit of side-rain (albeit it was at an angle, not direct) over the weekend in lashing rain and no ingress, at least nothing I could see.
Both. If enough people call the call centre it will get raised and passed across when the trend is spotted. Same with dealer but can take slightly longer for the comms to happen.I think they were both at the top - definitely weren’t at either end of the zip run as had always thought that was more suspect.
Additionally when we closed the roof after returning to the van and spotting the leaking I left the sliding hatch open as thought would allow some air to circulate in the upper bed at least. In practice about half an hour later we also then had water dripping through the zip or seam (not sure which) from the front window which was hanging down through the hatch (lowest point so water had pooled).
Having now had a better look and emptied the cupboards, stuff is wet in the left hand kitchen cupboard so water must have gone down the joint between the burner unit and the side panel - not surprising given the volume of water.
Haven’t had a chance to get hold of the dealer today as been a mad day at work, but worried that water will be properly behind cupboards and manifest itself later as either smelly soundproofing or damaged electrics, and no obvious way to be sure.
Is the dealer best port of call in the first instance in people’s opinion or is there a central VW centre to contact ?
No sound proofing and few adsorbing materials in the Cali's internal construction. So long as you dry out (keep windows/doors open to allow air movement) you should be OK after an incident like this.I think they were both at the top - definitely weren’t at either end of the zip run as had always thought that was more suspect.
Update - Spoken to the dealer who confirmed they haven’t had a van returned with this issue , although he said one customer had spoken to them about actually having leaks from the vents but had taken the advice in the owners manual to leave the zips at the upper position and haven’t had any further leaks!First night in the rain this week and leaked from all 3 vents! I will be in touch with the dealer today and post their response
I hope this is the outcome, as I really don’t want the bellows being stripped out and replaced. We’d do it ourselves (the tape) but don’t want to try anything that may give VW an option to wiggle out of a warranty claim.Your all going to end up with some magic tape on the bellows. Job done
I think you will find speaking to the garage you bought it from & asking them calmly to fix it is usually far more effective, going in guns blazing threatening to go legal is not really the best way to get your dealer on your side.In order to progress in getting it sorted, the legal route normally achieves quicker and satisfactory results.
Best of luck![]()
