Good afternoon,
The steps of how to refill AdBlue is in the handbook. In the MFD it will tell you the minimum and them maximum of AdBlue.
If following the steps in the handbook correctly, and stick the the min and max amount, the refill of AdBlue is straight forward.
The way I understood is that if less AdBlue is refilled as the minimum amount mentioned in the MFD the system won't recognize it. If more AdBlue is refilled there is a danger of overfilling.
But overfilling doesn't mean it just runs out of the tank, it seems it contaminates the sensor of the AdBlue tank. If this happens it is more than likely that it had to be cleaned and a system reset. Also the way I understood is, to clean the sensor the entire AdBlue tank system has to be uninstalled, sensor cleaned, tank re-installed and system reset. Like many things with VW that is expensive. I believe I saw here in the forum post saying that the cost could be several hundred Euros (well, sorry pounds).
I refilled my AdBlue tank for the fist time a few weeks ago (before that I went to VW). I ensured that I kept well above the minimum amount, but about 0.5 l under the maximum amount. Also followed the steps as outlined in the handbook to a "T". I had no problems.
My problem is that I have an unknown amount of AdBlue still in the 10 l canister. Which makes it a little bit difficult to judge the refill next time.
Regards,
Eberhard
