L
Lowlec
The 3 years Ive had my works van T6,......as soon as the indicator appears on the MFD, I fill it up to the max Every time with no issues!
I don't also.I don't understand all the fuss about AdBlue. It is very straight forward, the dash display tell one how much to add, max and min amounts. Don't add more than the max - simples!
On the same isle as HGV diesel, yes.On the HGV Diesel pump?
Cross purposes I think as I was referring to Diesel pump nozzle NOT the Adblue one which is standard.On the same isle as HGV diesel, yes.
Good question! I didn’t do the two things together ( I buy diesel from ASDA). I’ll check next time I go and report.Cross purposes I think as I was referring to Diesel pump nozzle NOT the Adblue one which is standard.
ie fill up with Adblue in HGV area then have to transfer to car area if diesel required.
HGV pumps deliver fuel at a much faster rate and usually Kiosk Operator won't turn the pump on.Good question! I didn’t do the two things together ( I buy diesel from ASDA). I’ll check next time I go and report.
Have never seen an AdBlue pump at an ASDA serviced.Good question! I didn’t do the two things together ( I buy diesel from ASDA). I’ll check next time I go and report.
Good question. Some sources suggest Add Blue has a shelf life of 12 months in normal conditions: between -11 and +30c. This would suggest that the Add Blue in your tank could have deteriorated somewhat in the four years of no use. In 500 miles, you might still have 12L in your tank. In my non-professional opinion, there is a chance that your DPF system would be just fine, but the sensors are sensitive and a failure of any part of the system is expensive to repair. At the very least it would require diagnostics, which might be covered under warranty. I think in your case, I would attempt to withdraw as much of the existing Add Blue out of the system and then refill it with the same amount and see what the readout on the dash says after that. Otherwise, ask your local service centre for some help. Good luck.Camper has done very few miles (<500), consequently the AdBlue has not been used in any great quantity. The bulk of the remainder in the tank (c.6 /7 lts?) is 4 years old; should I pump it out and add new?
Same here it’s a simple process. Last year we were in Wester Ross / Sutherland, needed to Adblue, bought couple of 5 litre containers from a tiny petrol outlet, job done. Obviously the cost was greater which was understandable given were we were but we simply used the funnel supplied with the containers, no problem at all.I don't understand all the fuss about AdBlue. It is very straight forward, the dash display tell one how much to add, max and min amounts. Don't add more than the max - simples!
Another thought. There is a recall on the T6 I believe to have the DPF system updated and they offer free refills if you have it done. They might empty and refill your system if you have that done? Worth a try.Camper has done very few miles (<500), consequently the AdBlue has not been used in any great quantity. The bulk of the remainder in the tank (c.6 /7 lts?) is 4 years old; should I pump it out and add new?
What is AdBlue? Parkers explains
Many modern diesel cars use a fluid called AdBlue, which helps reduce harmful emissions. Parkers explains exactly what AdBlue is, how it works and when to refill it.www.parkers.co.uk
