Aw really I didn’t realise. I’m new to it all. I personally would rather have an automatic but just wondered if mechanically there was a huge difference. Like you said probably a case of each to their own. Thanks for replywhere's that can of worms when you need it?
IMHO I think the DSG is better, but you might as well have put up a poll on this, as each will defend their choice.
We prefer automatic, it’s a real plus on long distance drives or in slow moving traffic jams. Works for us, but it’s not for everyone.Hi is an automatic just as good as manual? Any pros and cons advice? Thanks
We prefer a manual van as it can easily be bump started if you should end up with a flat battery, and easily towed should you get stuck in a field.
It's also very difficult to bump start a vehicle that needs to have the clutch depressed during startingI was told by the AA you would not start a diesel by bumping " When normally starting a modern diesel engine, it typically uses glowplugs to preheat the cylinders. If a battery is completely discharged then it may not provide the necessary electrical power to "glow" the glowplugs, making the push starting of a diesel vehicle with a dead battery almost impossible." How many campers would it take to push a Cali anyway?
Our Beach is 150bhp manual and works well for us. We prefer a manual van as it can easily be bump started if you should end up with a flat battery, and easily towed should you get stuck in a field.
Our runabout car is 247bhp DSG 4x4 with flappy paddles which is good fun. Super smooth, Auto is better in traffic (& snow, but we don’t get much !) but costs more to service and has a lot more to go wrong.
Manual / Auto both have their benefits so down to personal choice.
When was the last time you bump started a car ? DSG easily towed out a field just put it in N.
Whatever your choice Manual Gearboxes are on the way out. One of the greatest effects on Vehicle Emissions is the " Driver " , wrong gear/wrong revs etc: etc:. Replace the Drivers interaction with the Gearbox by a computer and you can make a significant difference to Emissions.
Autonomous vehicles will not have Manual Gearboxes.
