Avoiding roof corrosion?
I
itguy
Melton Mowbray, Leicestershire, UK
T6.1 Ocean 204 4 motion
Hi Everyone
One of things I have been wondering about for a little while now is if there is any well known ways of trying to avoid the roof corrosion issue on a brand new T6?
We'll be lucky that we can store our Cali in our garage and it will be used as a holiday/fun vehicle, not every day but still, are there any precautionary / pre-emptive measures we can take?
H
Hotel California
Europe
Cali now sold
No ....affraid not .
H
Hotel California
Europe
Cali now sold
Dehumidifier in the garage?!
No , ....affraid not .
I take very good care of my Cali , pull of the roofseal and clean/dry afther ever wash (that is afther every trip) , always stationt in a garage when not in use , not a daily drive.....a 2012 SE that is
No use , unless you try and separate the metal from the alu on your roof it will corrode.
But you don't have to worry , you orderd a 6-er and VW has solved the proplem so they say.....not .
sbmcd
sbmcd
T5 SE 180
Hi Everyone
Is your one pre or post Dec 2016, if post you should have the tape between the seal and the roof. If you do not have the protective tape it is worth fitting some before any corrosion starts, worth a try in my opinion. You should be able to see it just above the seal..
Now see it is new, should have the tape.
Lloydfred
Lloydfred
2010 2.0 140ps California SE Fresco Green
UK
T5 SE 140
I've often wondered if having the roof wrapped in clear might stop corrosion?
sbmcd
sbmcd
T5 SE 180
The area under the seal is the problem and that is where VW have added the tape, which is clear.
Lloydfred
Lloydfred
UK
T5 SE 140
Yes but what I meant was.
My bus is a 2010 and only has a very little light bubbling just above the seal in places. If I got the bubbling repaired then had my roof wrapped in clear, would it resolve any future issues. My bus i to old to claim on the VW warranty.
sbmcd
sbmcd
T5 SE 180
Is the bubbling only above the seal, usually starts under, you need to pull a section the seal off to check.
You could have the repair done, add the edge tape and fit a new seal but you would need to ensure the body shop did not bond the seal during the repair. Bonding is now part VW warranty repair procedure. If you spec the work you may get the body shop to fit the tape.
I am not aware of any T6's with the tape suffering the corrosion?
Ocean Spirit
Ocean Spirit
Eating Ice Cream, skimming stones.
Hampshire
Why do you say ensure they don't bond it if that's what vw are doing? Typo?
Lloydfred
Lloydfred
UK
T5 SE 140
I would suspect that VW don't want any further inspection of that area.
Its not like VW haven't manipulated a situation before for their own gain. I seem to remember a recent corporate emissions scandal.
Jabberwocky
Jabberwocky
Forever young (ish!)
My World
Me neither.....
Ocean Spirit
Ocean Spirit
Hampshire
Ah I see!
Or perhaps it's better at preventing further moisture Ingress hence better protection?
leightonjthomas
leightonjthomas
West Sussex
T5 SE 180
Ah I see!
I’ve just had mine back for the second time after repairs for bubbling under the seal and the seal was definitely NOT bonded. Admittedly mine is a T5 but I would have thought that the repair procedure would have been the same as for a T6.
I
itguy
Ah I see!
My understanding was that the tape went on to avoid the metal gripper of the rubber wearing through the paint (ie still quite soft paint when only a few days old when new and roof assembled on to it) and then causing rust??
Maybe i’m wrong?
Jay20cali
Jay20cali
Uk
Maybe i’m wrong?
Makes sense I’m a painter and what you say is correct.
mine a t6 has a strip of clear plastic tape between the seal and roof to prevent the problem with dissimilar metals contacting.... BUT how long it will last is anyone’s guess landrover Defenders had the same problem around the cappings
United Kingdom
T5 SE 180 4Motion
And they never managed to stop that after some 70 odd years. Instead they just stopped production.:thumb
L
Vantastic2
Vantastic2
RonB
richv
CaliforniaDAN
CaliforniaDAN
O
Aleve11
Aleve11
