4 year old van, awning starts to rattle, ( I have the additional plastic anti rattle widgets, which initially stopped the factory rattle) , which has now returned and slight crease when rolling the awning away.
long trip coming up so defo don’t want the rattle so I decide to investigate.
open the awning 10cm or so, to check the location of the anti rattle widgets, which are still in place !
I notice the RH support arm is slightly lower than the LH one and quite close the the lower edge of the awning casing.
when I push the RH arm up it moves ?
opened up the awning a little more so I can see what’s what.
I notice when I push the RH arm up a gap appears in the bracket which secures the arm. Low and behold the bolts are loose, particularly the top bolt / nut , which has allowed the RH Arm to drop enough so it make contact with the casing intermittently which is causing the rattle.
13mm spanner, tighten the nuts, go to the other end to check the LH arm, although that has not dropped, the bolts are loose.
Rattle solved
photos of the offending parts below (photo 1 & 2 show the gap / no gap ) I pushed the arm up then tightened it with the gap showing, last photo highlights the two nuts at either end of the awning
simple fix and sanity for my long trip, so,bed the slight creasing.
I will apply some blue thread lock after my trip ( can’t find it ATM)
