Goldie
Owen,
Both your measurements are within 1cm of mine. The back of the cabinet would slope forward at the same angle as the back of the drivers seat from a height of 43cm, which is the same as the seat/bed height. It needs to overhang the bed unit by 18-19cm to accommodate the depth of the SMEV unit. Not a problem for the wife and I as we're not tall and all the weight will be in the base of the unit.
Got a quote for all the bits, I'll source gas fittings in NZ as they use companion valve (3/8 BSP LH and you can't get Gaz 907 there):
Smev 8821 R/H sink - £165
2 x (4 x 4) sheet furniture board - £125
2 x water hose
2 x waste hose
2 x 8mm copper gas pipe
Submersible 12v pump
Gas bottle holder
8mm compression joint - £35
D.G. T-trim x 10m - £10
D.G. Door trim x 5m - £10
3 sets of cranked hinges - £12
3 sets of door latches - £14.25
2 x 12l water containers - £25
Total £396.25 - less 5% discount
Total £376.45 + £15 delivery
Total £391.45
I have also bought the VW clamps for the rail at about £10 each.
I'll start with an 8mm or 12mm thick piece of mdf to make the first one (templates).
Andy
2 x water hose
2 x waste hose
Gas bottle holder
Total £391.45
Andy
