soulstyledevon
Kennycalifornia
- Messages
- 6,460
- Vehicle
- Cali now sold
This week I achieved 265 with 55 range left...
Similar figures to me. But yours is a 4m...?
I presume if a 204 hp engine/4WD is fitted the driver tends to use the extra performance for the fun of it regardless of the extra cost. If those figures are correct and the engine is not defective a 80 ltr tank would still be too small for me.Similar figures to me. But yours is a 4m...?
Well I have a 180 4Motion with a 80 Litre tank and easily get 500 + miles and definitely use the extra HP.I presume if a 204 hp engine/4WD is fitted the driver tends to use the extra performance for the fun of it regardless of the extra cost. If those figures are correct and the engine is not defective a 80 ltr tank would still be too small for me.
I normally have at least 400 miles on the odometer before I refuel (70 ltr tank) and I do not wait for the warning light. Mind you if you are a press on type driver you would not enjoy being behind me on a single carriageway road.
Normally down to 1/4 tank before I fill up, on the gauge, and milage covered normally 450-480 at that point and MFD range showing anything from 60 - 120+ miles.
So a big difference compared with the T6 equivalent.
And so you should be.Yeah, but you probably used about 15 litres of oil too
And BelgiumAnd Denmark …
Do you think they have carried out an “update”? Might be worth a thread on it’s own if you think they are detuning our vans?I had a service on 22nd Jan and have now returned from a trip to France. No noticeable DSG issues. Local/short runs are giving 29 ish MPG both here and in France.
Fuel to ferry in UK 33mpg, France, ferry to home 30mpg. Windy.
return trip had 33mpg to French ferry and 36mpg on the UK run back home. Calm weather.
Both below high 30's previously found on same run.
Biggest difference is that it now has much less top end power, noticeable out of roundabouts or lane changing to match the speed rate of the outer lane. feels like as much as 10PS loss of power.
No comment from Dealer when queried on any changes made.
This was in response to an earlier sidetrack relating to this, in this thread. I should have put it as a reply.Do you think they have carried out an “update”? Might be worth a thread on it’s own if you think they are detuning our vans?
I'd just carry a 10ltr can of extra fuel to add when tank was down to 3/4 or a 1/2 if on a 500 mile run with no Service Points for fuel..So looking at this again...
The biggest annoyance with my current van is the 70l tank. The range is very much comprised.
The van has 22k miles and i average about 30mpg around 350-400 miles if I'm lucky.
So the question is if anyone reads this,
Has anyone retro-fitted the bigger 80l tank...?
Don't have an issue with my 70 ltr tank with over 400 mile range. Grew up with cars that only did 180 or so miles on a tank, 300 was good.
I regularly manage over 600 miles on our 80 litre tank, on good runs.For what it's worth, we have a new Beach with an 80l fuel tank. I filled it right up yesterday and it then stated the range was 500 miles. It has only done a 1000 miles so far so it's too early to give any form of brim to brim mpg figure. I let it do a few more miles before I work that out.
I also bought exactly one gallon of Adblue from the pump. This precise ammount was really to find out how much it was for a gallon. It cost me £2.73.
The 10l difference is 2.2gallon. At 35mpg that would suggest 77 miles added range from the 80l tank.The difference on long journeys canbe 100-150 miles.
A seventh further.The 10l difference is 2.2gallon. At 35mpg that would suggest 77 miles added range from the 80l tank.
Yes but the post I referenced suggested it could be 150 miles difference which would require 68mpg.A seventh further.
I once managed 997 miles from a 75 litre tank in my Peugeot 406.
