Take out the fuse for the rear interior lights;
Or you should be able to program them out with Carista dongle (or simliar), so that they switch off if key is not in the igniton. Options from an older post as below:
Doors / Windows / Remote
Auto-lock doors when moving
YES / *NO*
Auto-unlock doors when key is taken out of ignition
YES / *NO*
Auto-lock trunk when moving
YES / *NO*
Unlock trunk when doors are unlocked
*YES* / NO
Blink turn signals when locking/unlocking with remote
*YES* / NO
Beep when locking with remote
YES / *NO*
Beep when unlocking with remote
YES / *NO*
Beep when alarm is armed
YES / *NO*
Unlock doors via remote
DRIVER'S DOOR ON 1ST PRESS, ALL ON 2ND / *ALL DOORS ON 1ST PRESS*
Enable settings for opening/closing windows and sunroof
YES / *NO*
Open/close windows via long-press on remote
*YES* / NO
Open/close sunroof via long-press on remote or key
YES / *NO*
Open sunroof via long-press on remote
YES / *NO*
Close sunroof via long-press on remote
*YES* / NO
Open/close windows by holding key in door lock
*YES* / NO
Blink turn signals when done closing windows via remote
*YES* / NO
Re-lock doors automatically if you unlock, but don't open a door
*YES* / NO
Enable remote control buttons when ignition is on
YES / *NO*
Instruments / Display / Dings
Instrument cluster language
CHINESE / CZECH / DUTCH / *ENGLISH (UK)* / ENGLISH (US) / FRENCH / GERMAN / ITALIAN / NORWEGIAN / POLISH / PORTUGUESE / RUSSIAN / SPANISH / SWEDISH / TURKISH / NONE / SYMBOLS (NO TEXT)
Instrument cluster region (affects ext. lights too)
GERMANY / EUROPE/OTHER / USA / CANADA / *GREAT BRITAIN* / JAPAN / SAUDI ARABIA / AUSTRALIA
Temperature display units
*CELSIUS* / FARENHEIT
Distance display units
KM / *MILES*
Speed display units
KM/H / *MPH*
Pressure display units
*BAR* / PSI / KPA
Volume display units
LITERS / *GALLONS (UK)* / GALLONS (US)
Time display format
*24H* / 12H AM/PM
Date display format
*DD/MM/YY* / MM/DD/YY / YY/MM/DD
Consumption display units
*MPG (UK)* / MPG (US) / L/100KM / KM/L
Multi-Function Display
*ENABLED* / DISABLED
Seat belt warning
Lane-change turn signal auto-flasher
Lane-change turn signal auto-flasher count
1 FLASH / 2 FLASHES / *3 FLASHES* / 4 FLASHES / 5 FLASHES
Lights
Daytime running lights
ENABLED / *DISABLED*
Allow configuring daytime running lights via dash display
YES / *NO*
Coming-home lights (req. auto headlights or manual flick of high beams)
Leaving-home lights (req. auto headlights)
Coming/leaving-home lights use…
LOW BEAMS / *FOG LIGHTS*
Coming-home lights duration
10 SECONDS / *15 SECONDS* / 20 SECONDS / 25 SECONDS / 30 SECONDS / 35 SECONDS / 40 SECONDS / 45 SECONDS / 50 SECONDS / 55 SECONDS / 60 SECONDS
Leaving-home lights duration
Turn off front fog lights when high beams are on
YES / *NO*
Cornering lights (using fog lights)
Turn on cornering lights when turn signal is on
*YES* / NO
Turn on interior lights when key is taken out of ignition
*YES* / NO
Flash brake lights in emergency stopping
YES / *NO*
Flash hazard lights in emergency stopping
*YES* / NO
Brake lights work even when ignition is off
*YES* / NO
"Euro" parking lights when ignition off, turn signal on
Other
Activate side mirror heaters when rear window defroster is on
YES / *NO*
Automatic wipers (using rain sensor)
Speed-dependent windshield wiper speed
*YES* / NO
Additional 'tear' wipe after windshield washer use
YES / *NO*
Auto-enable rear wiper when front wipers on and reverse gear engaged
*YES* / NO
Horn works even when ignition is off
YES / *NO*
