gileswater
>i have also posted this on the beach bouncy suspension thread <
i would value any opinions regarding my beach on this suspension topic.
i own a t5 2015 Beach van .
Almost immediately after purchase i started to try and improve the sloppy suspension,
I had no concrete advice as how to achieve this ,uniquely forums etc,,,,,
firstly by fitting Eibach springs which are sold as a VW option in the cali/beach catalogue .
(These springs apparently reduce the ride height by 30mm.)
at the same time i also fitted a set of sports line wheels (18" 255/45) also from VW options
with the intention of increasing tyre > road surface area (and also because they look good )!
then a a bit later ,fitted a set of H&R rollbars (2or 3mm ( cannot remember precisely) thicker than OE)
And the result ?
the h& r bars were the single biggest improvement to handling preventing the vehicle from swaying all over the place around the bends and sharpening up the steering ,
As for the rest , i found the eibach springs to be mismatched to the oe dampers ,the suspension would occaisionally bottom out (over speed bumps for example )... and unfortunately /strangely produce an uncomfortably stiff/hard ride .
So maybe i made too many mods to quickly , but
After living with that set up for a year and still not contented with the result i deciding to seek further improvement and have replaced the OE dampers with a set of bilstein b8 dampers and in combination with the eibach springs this has resulted in much better damping and no bottoming out
but it is still delivering a hard ride whicjh becomes quickly tiring .
is this due to the wheels or springs ?
i suspect the springs
the bilstein dampers appear to have always been highly recommended for the t5 in combination with a shorter spring . and the ride was hard before fitting them.
but there do not seem to be any short lengths /softer options out there ? maybe H&R
as for the wheels I havent yet fitting back on the OE wheels to compare the difference .
So the next step ???
I have several thoughts and would appreciate any advice
a) return to 16/17 "wheels
b)H&R springs as mentioned above (softer ? with 40mm drop) in combination with the B8 dampers (or other spring )
c)OE springs in combination with bilstein b6 dampers,raising the height
d) return to the OE suspension ,retain only wheels and rollbars
And the result ?
