Chrisp
I managed, job done fingers crossed. Weird thing happened with the cupboard strip light after fitting. It was permanently on, then off, seems to working normally now.About halfway through my guides first post I describe how to remove the battery. The unit above the battery is what converts 240V EHU to battery juice.
Fitting a Solar Camper Solutions 100W Panel to a MY21 6.1 Ocean
Part 1. After deciding to buy one of the @Roger Donoghue kits I thought it could be of benefit to any others with my specific spec to see how I did it. Everything is more or less in Rogers instructions, but I did find them a challenge to understand due to how they seem to have evolved over time...vwcaliforniaclub.com
This will almost certainly end in tears or, at least, dissatisfaction.And the instructions that came with my panel said to put the black wire to the negative, not to the clamp, so I did that
I have a T6 like the OP, and my solar panel is directly connected to the negative terminal too. Never had a problem for 2 years. The battery of the T6 is not connected to the chassis in the same way as on the T6.1.This will almost certainly end in tears or, at least, dissatisfaction.
I'll see if I can find some examples and add them to this post.
Edit: Here's one.
Seems right. The seller of the panel says this:I have a T6 like the OP, and my solar panel is directly connected to the negative terminal too. Never had a problem for 2 years. The battery of the T6 is not connected to the chassis in the same way as on the T6.1.
Yeah, sorry I misread t6.1.I have a T6 like the OP, and my solar panel is directly connected to the negative terminal too. Never had a problem for 2 years. The battery of the T6 is not connected to the chassis in the same way as on the T6.1.
