Ozzy Pete
How many miles have you done in the past year between having the new battery fitted and now?Update:
With the battery replaced the cold start problem has so far dissapeared.
Thanks all for your comments and help.
8k but I must admit I don't think the problem truely went away perhaps my post (immediately after battery change) was premature and optimistic. I'm posting again now just because I have a little time to think about it and take easy action (like fuel filter).How many miles have you done in the past year between having the new battery fitted and now?
Great tripSomething like this.
Chamonix -> Furka Pass -> Dolomites -> Ancona/Patras/Athens -> Kalymnos -> Datça -> Geyikbayiri -> Athens -> Leonidio -> Athens/Patras/Ancona -> Sardinia -> Chamonix
We are climbers all these are climber destinations also often very close to the sea.
re: 90/180
You can use Turkey/Croatia. My partner and I are both dual nationals (EU one, and NZ other) so we are fortunate to have more flexibility. For NZ bi-lateral agreements help provide more flexibility in schengen.
Robin,8k but I must admit I don't think the problem truely went away perhaps my post (immediately after battery change) was premature and optimistic. I'm posting again now just because I have a little time to think about it and take easy action (like fuel filter).
The fuel filter should have been changed at the last full service. But they are only about £30 for a Bosch filter on Ebay and are easy to change anyway.8k but I must admit I don't think the problem truely went away perhaps my post (immediately after battery change) was premature and optimistic. I'm posting again now just because I have a little time to think about it and take easy action (like fuel filter).
When I fitted a fuel filter I primed it with a syringe. Filled it right to the top. That was 6k miles ago. Started instantly and ran perfectly after.One word of caution
do not attempt to fit a fuel filter yourself unless you have VCDS etc or can prime the filter another way.
the fuel filter must be primed before attempting to restart the Van , this can be done by the dealers system or VCDS.
failing to prime the fuel filter will prevent your van from starting (severely)
