Defender90
Hi i like the tent cane idea could you tell me where you bought them?Further
images
View attachment 77442View attachment 77443View attachment 77445View attachment 77444
The power door opens and closes fine but the top rear corner when fully open can push the Kampa adapter off the van side.
If you had the Comfortz additional side pieces then these would follow the door and not pull the adaptor with them.
Finally, a couple of general issues with the awning room.
I was particularly concerned at rain ponding on roof so made 2 bracing poles.
Unfortunately, I cannot find where I ordered these from (think it was Amazon but not showing in my order history) They were good value and two in a pack, each pole is 3 section and adjustable to the awning whiccan then tension the roof on to them
For added support I also have fibreglass tent canes that run from each corner of the roof and force a slope dome which shed water really well and no sagging even in a downpour.
Lastly, I think that the gap between the roof and the sides attached to the arm could be easily closed with a piece of foam pipe insulation (probably 22 or 28 mm pipe size) slit open and pushed over the arm .
Hope the images help.![]()
