Borris
I too suspect that there's a substantual element of income generation in vehicle service regimes and why not dealers service depts aren't charities. However, let's not forget that there's also a very valid reason why the Cambelt, tensioner, and waterpump are changed at recommended intervals. A premature failure would be extremely expensive to fix and I suspect the service intervals are set to avoid that occuring, based on historic evidence.when they change brake fluid I suspect they just syringe it out of the reservoir and tip some new stuff in. that means all the old fluid is still in the lines. do you think they go round and bleed all the old fluid out of each cylinder ? I doubt it. as usual probably best to do it yourself if you think it needs doing.
as for inspection I just ignore it.
as for spending 50k plus on a van and ignoring future costs I never spent that much on mine but still wasn't easy raising that much cash for a vehicle. as pointed out just because you did doesn't mean you should constantly get your leg lifted by VW afterwards
20k cam belt change anyone ?
As for brake fluid changes, they aren't that expensive and if done properly are usually done by bleeding the system using the nipples on each brake caliper.
