t4_lad
Its not easy being green...
Thanks for the help! Much appreciated...It's easy done. It's good you persisted with the fault. Others would have given up. It's good both are set up to charge now.
Sent from my ONEPLUS A5000 using Tapatalk
I persisted because I want to sleep well that the vans not going to burst into flames. Can't be too careful with such things...
Strange though (or maybe not) that the meter and 'cheapy' voltage display are also quite different... but I guess the clue it's in the comment... Will trust the meter (now it's on the right setting!) in this case.
Next job the water level sensor
Cheers!
