NewForestKnight
We have an older (T5 / 2008) Cali which is not used so much in winter, maybe once a fortnight or less at times. I keep it on EHU to keep things topped up, but it does get quite a bit of condensation inside the windscreen particularly with the freeze/mild cycles we've been getting.
Was thinking of getting a small oil filled radiator to keep on frost protection setting generally to help with condensation and avoid freezing van bits, but also to use for overnight heating if we're away and its cooler - rather than a fan heater which can be noisy.
Has anyone tried this, and has any recommendations? Is the frost protection likely to work and reduce condensation? Any thoughts welcome!
