Gas Problem - Help!!
tim batten
tim batten
Holmfirth, West Yorkshire
Cali now sold
We are currently travelling around Spain and Portugal, and we are having gas problems! The pressure is very inconsistent and sometimes, there is not enough pressure for the rings to light. I have checked everything obvious. There is gas in the bottle (I actually bought a new oneon a campsite in Bilbao to be certain -a bargain at €13.50 for a full 907!!), the connection to the regulator is OK, and the tap is on under the worktop. All I can think of is that the regulator has become faulty. It has worked fine for the last 3 years. Has anyone else had a problem with the regulator, or can anyone else suggest any other reason for our problem? Luckily we have a Remoska electric pan with us which is fine when we have hook up, but at other times it is a real pain. Thanks for any suggestions. Tim and Caroline.
Leo K
Leo K
Netherlands
T5 SE 180
Maybe the temperature in the gas compartment is causing the problem? I read the minimum temp to use butane is 4 degree C - in my experience trouble starts at considerable higer temperatures.
tim batten
tim batten
Cali now sold
Thanks for the suggestion Leo but temperatures here at the moment are well above that - around 10 deg min. Also, last winter we were in Andorra in freezing conditions and the gas worked just fine!
John
John
West Sussex
slowcoach65 said:
My guess would be the regulator :?:
Andy
I agree Tim in that I think your original diagnosis of the Gas regulator is the problem.
John
Simon Kelly
rod_vw
rod_vw
michaelj70
10K
Wesel
Wesel
Moakesy
Moakesy
Moakesy
