G
gover100
Following a successful jump start and a couple of hours scratching head and playing with a multimeter (and the control panel) I have learnt a few things that I'd love to know match others experience?!
Sorry for rambling post...
The leisure battery was 100% charged and the vehicle battery was dead (<10v). In this condition, there was no battery-to-battery charging. Despite a full leisure battery and connected to EHU, no charging of vehicle battery performed.
Drove 20 miles (after jump start) and leisure battery still at 100%. Vehicle battery + 12.02v
Plugged into EHU, ran heating on electric 10amp, turned fridge on.. just testing things. Leisure battery showed charging and 18A 12.1Vv Vehicle battery 12.1v.
Turned fridge and heating off - nothing else being used - leisure battery still charging on EHU. Shows 16A load 12.2v? vehicle battery 12.2v. 30 minutes later, both batteries at 12.3v and a steady load of around 10A on lesiure battery. Now both batteries are at 12.4v
So, yes, there appears to be battery-to-battery charging when both batteries are in a usable state of health. I am not convinced this particularly smart... It appears to be independent of the isolation switch - ie, with that off the leisure battery still feeds ths vehicle battery.
The fully charged leisure battery was down to 70% by now, even with EHU. Leisure battery is happily sacrificed/balanced with vehicle battery?
I was told the step and everything from the cab 'bulkhead' forward is fed by the vehicle battery, everythin gelse by leisure. This is nonsense, lighting above the bed area and awning light are powered from vehicle battery as is 20A 12v feed at rear of vehicle. Will test 12v usb and other lights later.
I am off to study the french wiring diagrams found on this forum (thank you) and fusebox layouts. I am baffled as to why both batteries were depleted in 27 days. Oh, I think VW has some battery protection to prevent the vehicle battery from dropping too low... I will be hunting for the battery drain for days I suspect*.
If anyone else has any insights on how the electrical system works, i'd love to hear them!
*current favourite source is the entertainment/we connect system, i think it may be able to continue to download/install updates with ignition off.
