Unfortunately so hard to keep it off.After driving through rain my step (the retractable step for the side door into the habitation area) gets covered in road grit and dirt. Is this normal?
Hi Will, has the dirt and grit caused any problems with the step sliding smoothly in and out?Unfortunately so hard to keep it off.
Hi TopsyHi Will, has the dirt and grit caused any problems with the step sliding smoothly in and out?
I think you had a new step fitted and was the new one any better at keeping the dirt and grit out? Does it still work smoothly?
Ive just fitted a set of the genuine VW front mudflaps, £55 & takes about 10 minutes with 5 screws each into predrilled plastic holes. Am hoping the drivers side will keep a fair bit of mud off the step & the passenger side will reduce the amount of dirt sprayed up the side.
