How many watt the VWT6 ocean with 2 standard batteries support?
EUGENIO
EUGENIO
BRUSIO
T6 Ocean 204
Hello,
how many watt does the ocean T6 support on hook, not on hook and with the motor on?
Thanks!
Depends on where you are drawing the power from.
Can explain what you want the power for?
Hi!, thanks for the answer! i would like to know if i can use a 1,560-watt blender.
And if i can use it on hook, not on hook and driving.
Thank you very much!
Assuming this is a 240V blender, then you can only use it on hook up. The inverter will only provide 150W, so that won't work. If it was 12V you wouldn't be able to use it at all as there is nowhere to get a 12V, 130A supply.
Thanks, what about a blender with 600 w always 240V?
If is not working are there some inverter or maybe i can change or add batteries?
best
I can only speak for the UK but most EHU here are 10amp or 13amp.
To give you an idea assuming 230v...
6 Amps 1,380
10 amps 2,300
13 amps 2,990
Inverter is restricted to 150w
12v socket is 20a max which would be 240w (12volt appliance)
best
Maybe you just need a cordless blender? That links to a Kitchenaid one and a quick search reveals that it can be found on eBay for around £100. It has a charger rated at 220-240V, 18W which would work off hookup if you use the inverter.
There are probably others and I did see a hand cranked one as well.
