H
haydnw2
The soft close side door on our SE has always performed flawlessly - it works every time and there is no grinding, etc. But I'm curious how much force it takes to actually engage the electronic mechanism on everyone else's vans. We still need a bit of a shove to get it to the point where it latches. If I very slowly push the door shut from the outside then it will eventually reach almost-closed and the resistance stops all movement (without engaging the soft close). I then can't get the soft close to engage simply using the door handle; I have to give a press on the window at the back end of the door too. From the inside, I definitely can't get it to engage without a bit of a run up.
It doesn't cause us a problem per se, but the something I read in another thread a while ago made me think that it may engage more easily on other Calis. The need to shove means it's not really any quieter on a campsite at night than any other door. The retractable contact mechanism on the front end of the door seems OK, and I've cleaned the contacts with a fibreglass pencil (although they were OK anyway). There's no stickiness on either of the rails. Would be grateful to hear how sensitive somebody else's doors are!
