NickE
- Messages
- 152
- Vehicle
- T5 SE 180
I've had a problem recently when on hookup at two separate campsites. I plug in and everything looks good with correct charging symbols on the control panel (2013 SE) and positive amps. Then after 2-3 hours it stops charging and control panel charging symbols disappear. Unplugging and then plugging in again solves problem but it then drops out again after a few hours. Keeping on unplugging/plugging in finally gets you to a point where it stays charging and the leisure batteries get to 100%.
Anybody had the same problem or got any idea what maybe causing this?
I rarely use the EHU when on a trip, only using it to recharge the leisure batteries if staying put for more than 3 nights.
